i have $1200 and a 85 z28 with a 305
Old Dec 18, 2010 | 02:52 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
what should i do i have $1200 i really don't wanna pull the motor it runs fine i just want to make around 300 to 350 hp whats yalls opinion. thanks
Old Dec 18, 2010 | 05:00 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: i have $1200 and a 85 z28 with a 305
You can achieve that power with vortec heads, beehive springs/retainer kit, and a cam on a 305. Still keep it very streetable too.
Old Dec 18, 2010 | 05:37 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
350...or LSX
Old Dec 18, 2010 | 10:17 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Originally Posted by itsMikey
350...or LSX
Go big(ger) or go home
Old Dec 18, 2010 | 10:21 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
can i build a good 350 with $1200
or as i go lsx with $2000
Old Dec 18, 2010 | 10:58 PM
DAREDEVIL 1's Avatar
Car: CAMARO,GMC SUBURBAN DUALLY,RACEBOA
Engine: 305 TBI( soon 383),350Vortec
Transmission: 700 turbo
I would save my $ and my GF something nice and just drive it like it is for now !!!!
Then next year u can mod it the way u realy like and GO BIG ...just save some cash !!
HAPPY HOLIDAYS !!!!!!
Old Dec 19, 2010 | 12:04 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
LSx for $2000 probably not. But I know of a build for a 350 with vortec heads and lt4 hot cam that is costs $1150, but you would need a lot more money to buy everything to swap over, and all the extra things to add up.
Old Dec 19, 2010 | 12:24 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
i was going to buy some interior things but that can wait will 1600 get everthing i need for the 350 swap
Old Dec 19, 2010 | 06:48 AM
davidearlcox's Avatar
Be a role model. Drive the car. If it's running well now, keep your money in the bank.
Old Dec 19, 2010 | 08:25 AM
rich5's Avatar
Car: 91 camaro RS
cam, intake, + - carb, headers
Old Dec 19, 2010 | 09:04 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
heads, cam and headers...
Old Dec 19, 2010 | 12:33 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
What fuel system?
Old Dec 19, 2010 | 04:34 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
Originally Posted by FueledSoul
What fuel system?
it has a 4 barrle q-jet
Old Dec 19, 2010 | 07:04 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Stick with that and get a good tune with it.
Old Dec 19, 2010 | 08:06 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
1600 can put you verry close, you can start by buying the block and the rotating assembly and then buy the rest as you can, that's how i did mine
Old Dec 19, 2010 | 08:18 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
thats what i think im going to do its just i dont have the equipment to the swap but ill just worry about that when i get thier!
Old Dec 19, 2010 | 10:15 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Everything in this build will cost me right at $1300. If you get a smaller cam and don't do any head work to the vortecs, you could have a really cheap build like that.
Old Dec 19, 2010 | 10:39 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
**** for 1300-1400 im gonna build the 350 my mind is made up, do u have a list of the parts you are using that you could send me it would really help! thanks
Old Dec 19, 2010 | 11:26 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
I have a list on notepad, let me copy paste it, it also has a few prices idk how accurate though.
///////////MOTOR NOTES\\\\\\\\\\\
86+ 350 Vortec SBC (Powdered metal rods, good for 500HP
96-02 Vortec Heads
[Shortblock]
Vortec 350 SBC longblock - $125 (1-piece RMS)
Stock 350 Crankshaft
Stock 5.7 Powdered Metal Connecting Rods
Speed Pro Z8KH423NCP30 Hypereutectic Flat-top Piston and Ring kit - $165
Boring block .030" over, pressing pistons on rods, install cam bearings - $150
24502586 - GM Performance LT4 Hot Cam Hydraulic Roller - $225
Accel Large cap HEI - free
Accel 8mm wires - free
Flowtech Shorty Headers - free
Custom Y-pipe - free
Flowmaster
12499224 - GM LS6 beehive valve springs - $65
787-16 - COMP Cams Steel Valve Spring Retainers - $52
648-16 - COMP Cams Race Valve Locks - $22
SEALED POWER Part # ST2015 Valve stem seals - $1.84 ea - $30
Machining Screw in studs - $5 ea x16 - $80
Studs - $1 ea x16 - $16
Guide plates - $25
Edelbrock 9630 Hardened Steel Pushrods - $30
Edelbrock 7116 Performer RPM Vortec Intake Manifold - $188
Valve cover 4bolt adapter - $110
1.5:1 Roller rockers - Free
LS2 Timing chain 12586482 - $35
Autozone SBC gasket set - $64
Tell me if anything is wrong, I also need to update several things.
Old Dec 20, 2010 | 12:11 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
thanks bro ill let u know if anything is diffrent
Old Dec 20, 2010 | 12:30 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
what kinda of cam would u run with that set up
Old Dec 20, 2010 | 11:48 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
all you need really is a basic set of sockets/wrenches, torque wrench, cam wheel, and an engine stand. I know a few people with engine stands and I own one; and I am more then happy to let others borrow it. You shouldn't have to much difficulty finding someone with one.
Old Dec 20, 2010 | 11:49 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
If it's staying streetable I wouldn't go bigger then like .510" lift and that's already pushing it because you'll need an aftermarket stall converter.
Old Dec 20, 2010 | 11:56 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
im excited ill post pic when i start the build
Old Dec 20, 2010 | 12:00 PM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
cool thanks i want a nice streetable motor that will go when i need it to im tierd of 150hp
Old Dec 22, 2010 | 12:58 AM
91lsz28's Avatar
Car: 85 z28
Engine: 305 4bbl
so looks like im just going to build up the 305 for now vortec heads, intake, cam, headers and a new carb so wish me luck any idea on what kinda cam i should use thanks, and im going with e fans also
Old Dec 24, 2010 | 04:27 AM
Gabe88's Avatar
Go quick and cheap. spray it.
Old Dec 24, 2010 | 04:37 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
You could always just purchase a craigslist or junkyard block and freshen it up. No need to get all those brand new guts, stock rods and pistons (if they are straight) should do you just fine.
EDIT: With vortec heads your compression might be hurting a bit. Consider getting them milled? With Vortec heads the factory lift is limited. Right around .450-.470 according to most folks. Unless you're looking for more, I've seen the LT1-LT4 factory cams most commonly recommended. You'll have trouble finding anything in the aftermarket that caters to a lobe that small (believe me, I've looked). There is a GM camshaft on sale right now that probably lopes and chops in a really fun way, but it's pretty crap as far as performance goes. http://www.summitracing.com/parts/NAL-14097395/
Other than that, LT1, LT4, L98 all offer slightly bigger cams. I think I paid 30 bucks for my L98.
If you want bigger lift, there are several available options in the form of spring kits and headwork. Ask and ye shall receive.
Old Dec 24, 2010 | 07:14 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i might wait and save some more so when you build it up, you can do it right. look around for a big block or even a 350. i'm sure you can find one from a junkyard thats driveable if you really want something now.
look into 5.3L LSx swaps. those engines are a dime a dozen and give good power
jaridjohn
Jul 8, 2024 03:49 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
