no start
Old Dec 20, 2010 | 01:06 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
no start
ok, so i've got an engine thats been sitting for about 6 months after i replaced the crank and bearings because of spun bearings. finally got the motor in the car and all wired up, can get it to start, gas wants to spray out the top of the carb, had set it to tdc on the #1 by bumping it over with starter till a rag popped out of spark plug hole, to get it close enough to start, and set with light. anyways, after playing with timing, and spining the distributor 180 around still won't start. so i pulled #1 plug again and the valve cover to get tdc correct, but it seems that the piston is going up the whole time the intake valve is open, and down the whole time the exhaust valve is open. i'm not sure how i would have accomplished that, when i put the new crank in and put the timing chain on i set the marks to crank dot=12 o clock cam dot=6 o clock.
and the valves on drivers side are EIIEEIIE correct?
any help would be much appreciated
Old Dec 20, 2010 | 02:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which direction are you turning the crank?
Old Dec 20, 2010 | 02:43 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: no start
standing infront of the car was turning it counter-clockwise, forgot to say that, i searched for an answer to which direction it needed to go earlier and that was what i found
Old Dec 20, 2010 | 02:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: no start
Counter-clockwise is backwards.
Old Dec 20, 2010 | 03:49 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: no start
You didn't put the firing order on the distributor cap counter clockwise as well?
Both the motor and distributor turn clockwise.
I'm sure of that, but I'm not there with you so have someone crank the engine so you can see which way it turns.
The way you found the compression stroke is just as good as any other, however, turning it counter clockwise put it at TDC on the exhaust stroke unless the rag popped out after it passed TDC then counter clockwise would have put it where it needed to be.
Let us know when it's firing on all 8 cylinders.
Old Dec 20, 2010 | 06:32 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: no start
ah ok, no i had the firing order correct on the dizzy
will mess with it more tomorrow, though now i'm wondering again why it was spraying gas out the carb? just timing too far off?
Old Dec 20, 2010 | 09:14 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: no start
The ignition timing is not the issue. Your valve timing is way off. You will need to remove the timing chain and get it right
Old Dec 20, 2010 | 11:45 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
Re: no start
its been awhile since i had it apart, but i remember putting the dots basically touching, i couldn't have put the sprockets on incorrectly could i? if so what is the correct way of installing them?
also, just to be clear, you did read that i was rotating the engine backwards, and not base the valve timing being off just off of the first post?
will be working on it in the morning
Old Dec 21, 2010 | 12:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: no start
No
Old Dec 21, 2010 | 05:32 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: no start
If you were this close, you did it right.
Old Dec 21, 2010 | 11:44 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: no start
I apologize, I read over the thread too quickly, and was basing my thoughts on which valve you said was open with the piston going up and that the carb was spitting back gas when you tried to start it. But I guess turning the engine backwards would make it look like the piston was going the wrong way in relation to the valves, so hopefully turning it the right way while watching the valves will verify that it is correct. Keep checking things, I'm sure you'll sort it out
Old Dec 21, 2010 | 05:21 PM
five7kid's Avatar
Having the ignition timing off will cause gas spitting out of the carb.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
