What can i put in my stock 84 z28 camaro to make it faster?
Old Jan 7, 2011 | 09:14 PM
moneyz1's Avatar
i want to no what to put in the car to make my 305 reach its max with out haveing to swap to new engine and were to buy the parts to do it?
Old Jan 8, 2011 | 12:15 AM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: What can i put in my stock 84 z28 camaro to make it faster?
Way too much to factor in with your information. You can do heads/cam and see the biggest gain or you can do intake/exhaust. Their is just too many things to make your car faster but their is a lot of things to add up to reach that goal.
Old Jan 8, 2011 | 12:19 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You are going to need to study harder or your will spend money and it will end up worse in every way than it is right now.
Seriously help yourself and read related posts on this excellent site before you go looking for easy answers.
Old Jan 8, 2011 | 12:27 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
there is no need to start 2 threads with the same question.
Old Jan 8, 2011 | 07:29 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Judging from his handle, sounds like he can afford it. So all you need is to drop in a crank from a 400 with forged pistons/rods, bore it.... eh, .030 over or so, put on more free flowing intake, exhaust, and cylinder heads, larger camshaft, then pick your poison of forced induction. Personally I would use nitrous with a carb'd engine, but you can't go wrong with a supercharger or turbocharger with a blow through carburetor. As for parts, pretty much any performance parts shop that has anything to do with Chevrolet should sell parts for your 305.
Old Jan 8, 2011 | 09:48 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
don't forget a stall and gears
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Fronzizzle
Aug 9, 2015 01:15 PM
