Having a new 383 roller built, what do you guys think?
Old Jan 8, 2011 | 12:27 AM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
Hydraulic Roller
.510 .533
288 294
232 236 @.050
Probe Flat Top Forged Pistons
Forged I Beam Rods
Proform 750 DP Carb, Accel HEI Distributor
Aluminum Proform heads (builder buys the bare castings, then fully ports them, 5 angle valve job, installs good valves, springs, etc). He said the heads really arent bad but do need cleanup. If fully ported they are really hard to beat for the price.
10.5:1 Compression (maybe slightly less)
1 Year Warranty
And the age old "guess my HP" question. Hoping for upper 400's...
Old Jan 8, 2011 | 12:36 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Having a new 383 roller built, what do you guys think?
do you mean procomp heads?
Old Jan 8, 2011 | 12:48 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
yes procomp, thanks.... I have seen a lot of talk about them, apparently they were awful originally but the newer castings are a lot better. They still don't seem to be overly consistent from head to head, but with a little cleanup I'm hoping they will be fine. I am looking for a low reving torquey street motor, i knowif i'm skimping anywhere its on the heads... Can always add AFR's later right?
Old Jan 8, 2011 | 12:55 AM
"Can always add AFR's later right?"...unless a valve seat falls out which i heard of with those heads.
Old Jan 8, 2011 | 01:18 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
That's why they buy the bare castings, install their own valves, etc., and go over them completely. They are the ones that choose those heads, and warranty the entire engine for a year
Old Jan 8, 2011 | 01:32 AM
why are you having a new engine built? the one in your signature looks good. I have dart heads on mine too.
Old Jan 8, 2011 | 01:37 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
After 300 miles on that engine, the block is ruined. One of the starter holes is badly chipped, and it can't be fixed. Since i have to pull the engine anyway, i decided to go a little overboard. I'm going to sell the dart heads/forged innternals out of the other engine. I thought about buying a shortblock and moving my heads/cam, but I wanted to go with aluminum heads so i could run a higher compression ratio, and why not go full roller?
I can upgrade to a 3 year warranty, might not be a horrible idea with the procomp heads as metioned above
Old Jan 8, 2011 | 02:22 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If the heads are that good I would run lots more lift and maybe cut back on the duration
Guys are only running 230 /236 dur ( w/ .575 lift ) on high revving 383's
What intake?
Old Jan 8, 2011 | 09:18 AM
ShaneBuss2's Avatar
Engine: 357ci Carb
I'm running 224/224 now on a 350 and its pretty mild. I would think on a 383 230/236 with a full roller, and 110 LSA it wouldn't be an issue? Power Range on that cam is listed as 2500-5700. I wouldnt say the heads are going to be on line with AFR's or other top of the line heads by any stretch, but they should flow plenty, especially at ~500 lift to make a lot of torque. Hoping I can get over 400ft-lbs for the cam's listed powerband. I still have the stock rear end but 3.73 posi, so I will have to avoid sticky tires for a while.
I might do 1.6 rockers to raise the lift, but if i get it too high it will probably hurt given the heads. I appreciate the input on the cam, it's not too late to go with anything else. I really want it to be as streetable as possible even if I sacrifice some HP (I still have power brakes, need vaccuum). Most likely Edelbrock Performer Air-Gap, but not 100% sure on that yet either. Car looks pretty much stock, could be a good sleeper
Old Jan 8, 2011 | 10:24 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Get a performer rpm intake portmatched to the heads. That cam will want to go to 6300-6400 rpm easily and a good dual plane is a good match. Run 1.6 rockers to get that lift up. It will need it.
If the heads are ported right and good components are added, it should spin up very well and make very high 400's maybe 500 hp+. Close to if not over 400whp. Make sure the builder puts on good valve springs...something with over 135lbs on the seat and 380-ish open pressure or abit more to control valve float in the 6000+ rpm range. Beehives wouldnt be a bad idea or a typical LSx style small diameter double spring
Old Jan 8, 2011 | 12:25 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
Thanks for the advice. I am meeting with him Monday to go over the specifics, he will be port matching the intake either way.
He said the non roller-version of this combo (same cam specs) produced 465hp@5500rpm/512@ft-lbs@4500rpm on a engine dyno, i guess it's believable. If i get those numbers with the roller version i'll be happy.
Old Jan 8, 2011 | 01:15 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
my outside starter bolt whole was also chipped i'd say a 1/4 of it was gone. my local machine shop was able to fixe it did a great job almost looks like it never happened. built it up with nickel and redrilled.
Old Jan 8, 2011 | 05:29 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
hmmm.. Maybe i should leave the engine completely intact and take it to a machine shop. I was just about to pull the heads off..
RazorN8
Jan 7, 2022 11:44 AM
LT1Formula
Aug 20, 2015 09:36 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Street Lethal
Aug 14, 2015 08:25 PM
