WTf?!? new engine won't turn over!!
Old Jan 11, 2011 | 06:46 PM
jerryvarnell's Avatar
I just rebuilt and built up my 84 305 n put a lotta goodies in it.
First gen vortec heads
Edelbrock performer intake
Demon 650 carb
K and N cold air intake
Long tuBe headers
HEI distributor setup
Brand new starter
New pistons
The starter will engage but the engine won't turn overm
I've got 4 spark plugs out so its not a compression problem.
The battery is at 18 volts so its fully charged.
No ground wire problems.
Please reply asap or just text 4058089453 cause I'm goin crazy!!
Old Jan 12, 2011 | 12:27 AM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: WTf?!? new engine won't turn over!!
Can you turn it over by hand? Also why is your battery charged to 18v thats a bit high dont you think?
Old Jan 12, 2011 | 12:38 AM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Do you have the correct starter/flywheel installed?
Old Jan 12, 2011 | 03:01 PM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
check the bolts on the flywheel if you put on the wrong ones (too long)they will sit against the block and the engine will not turn
Old Jan 13, 2011 | 10:01 PM
vangogh4560's Avatar
Car: 1987 camaro lt
Engine: soon 383
sounds like you don't have the right starter on.. one will have the bolt holes side by side and the other will have it staggered
Old Jan 13, 2011 | 10:12 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
probably one of the above answers but something stupid ive done was over tighten the rockers and once the pushrod bent to touch the head it wouldnt turn any further. i dont know if you set preload, but hey, stupid mistakes help others learn so i guess my mistake isnt a total loss lol. that was a 'it wont turn by hand' situation so i dont even know if the starter being used would be different.
Old Jan 14, 2011 | 12:37 AM
spr250's Avatar
Car: Divorce stole it
Engine: Divorce stole it
Transmission: Divorce stole it
Axle/Gears: Divorce stole it
try to turn it by hand, if it rotates then its the starter. I just finished an engine swap on a truck and the starter worked for a few cranks then it would engage but not turn over. Turned out the started was junk. If it isnt that, then your jammed up somewhere
Old Jan 14, 2011 | 12:42 AM
spr250's Avatar
also when I build an engine, everytime I install the crank and pistons I rotate the assembly, cam and timing chain, rotate, valves and lifters I rotate, I know it takes a few minutes longer to finish but then I know that everything is moving right away and if something binds up I know where and I don't have to tear my engine back down to find and fix
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
