hard start when motor cools down
Old Jan 13, 2011 | 12:21 PM
ck1987's Avatar
Car: 1989 iroc z convertible
Transmission: auto
I have an 89 iroc convertible and it is hard to start when motor gets cold please help
Old Jan 13, 2011 | 12:46 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: hard start when motor cools down
TBI or TPI. in tbi its to be expected but tpi should be quick and easy to turn over. notice does your fuel pump engage imedietly when you turn the key froward or only after a bit of cranking if the fuel pump isn't engaging imeditly its basically not priming the system which means you will have no fuel to burn so no start
Old Jan 13, 2011 | 01:59 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Fuel pump should come on for 2 seconds when you first turn the key on. Then come right on when you turn the key to start. It could be that the check valve in the pump isnt holding pressure. It could also be coolant temp sensor. If it's TPI, it could be the cold start injector.
Old Jan 14, 2011 | 11:36 AM
ck1987's Avatar
Transmission: auto
It is a tpi I will try these things and see how they work
Old Jan 14, 2011 | 05:20 PM
Red 87 GTA's Avatar
somthing is wrong with it then hopefully somthing small but tpi is proberly the best setup for cold start anywhere when working correctly so get back to us after you try a few things or find a solution. hope its nothing big
Old Jan 14, 2011 | 05:28 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
i got the same problem, and mines carb'd.. 305.. wtf could it be? :s
Old Jan 14, 2011 | 05:42 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
BrandonSB, What year and model is your car?
Old Jan 14, 2011 | 05:50 PM
Red 87 GTA's Avatar
i would assume its the electric choke gone bad i recomend puting a manual cable to the interior for the choke
Old Jan 14, 2011 | 06:05 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The trouble with manual choke conversions is getting one with a decent cable. No one makes a decent choke cable anymore. They bind and kink and cause problems. Repairing the factory auto choke is generally a more satisfying result. Just need to understand how to diagnose and repair it. Most of the later units were electric and the electric thermostats fail.
Old Jan 14, 2011 | 06:11 PM
BrandonSB's Avatar
Engine: 30Slow
its an 87 z28.
Old Jan 14, 2011 | 06:44 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh, then you must have put the carb on it yourself.
Old Jan 17, 2011 | 11:32 AM
ck1987's Avatar
Transmission: auto
And another thing that is happening is that twice now i have gone out to start her and i have not been able to @ all then i charge the battery and the next day it takes a few tries but she starts
Old Jan 17, 2011 | 11:39 AM
foxmartin1's Avatar
Car: 1989 firebird formula
Engine: 5.0L V8
I have an 89 firebird formula and it takes between 3 to 6 tries to start in The cold. Possibly same problem? 305 tpi
Old Jan 17, 2011 | 04:45 PM
Red 87 GTA's Avatar
you may want to just replace all sensors and that may fix your problem completely.
Old Jan 17, 2011 | 04:58 PM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
i would do a fuel pressure test. but thats just me. or hell even just trying to replace your fuel filter, could be clogged and creating problems. cheap fix and if its not the problem well at least it was cheap.
Old Jan 17, 2011 | 07:03 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
CK1987 and foxmartin, Your symptoms sound similar. I would definitely check fuel pressure. It shgould come up when the key is turned on. Then when you turn the key to start the engine, pressure should come up to 40-45psi and stay there while you crank. You may also have cold start injector issues. Test the cold start injector by removing it from the manifold and holding over a glass jar while a helper cranks the engine. A strong spray of fuel should come from the injector while cranking a fully cold engine.
Old Jan 19, 2011 | 10:47 PM
ck1987's Avatar
Transmission: auto
Processes of elemination problem solved she needed a gas pump thank you all for the help. Now time for cosmetics!!!! Does anyone know where i can get a set of refurbished rims for my 89 iroc convertible I got a quote of $250 a piece to have some redone is that an average price?
Old Jan 21, 2011 | 05:08 PM
250 a piece is a pretty good deal. I usually see refurbishing's go for around 350 or so. It also depends on if you want the first gen iroc-z rims or the second gen. Then theres the third gens that came out in 90-92.. Not my fav.
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Leggman1
Aug 6, 2015 04:15 AM
