Milkshake machine
Old Jan 16, 2011 | 09:19 PM
Karasawa's Avatar
Car: KITT
Axle/Gears: 2.73 one wheel wonder
Milkshake machine
350 tpi engine, mixing water and oil, coolant appears to still be clean. took the heads off and the gaskets looked ok, so does that mean theres a crack in the engine block somewhere?
Old Jan 16, 2011 | 10:05 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Milkshake machine
blown intake manifold gasket.
It will allow coolant down but not up.
Old Jan 16, 2011 | 10:19 PM
Karasawa's Avatar
Car: KITT
the intake manifold gaskets looked good though
Old Jan 16, 2011 | 10:21 PM
Karasawa's Avatar
Car: KITT
it was also running rough and the timing didnt seem to want to adjust like it wasnt going into closed loop
Old Jan 16, 2011 | 10:23 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Well my issue is every time I have seen a blown head gasket or a cracked block (my experience is coming from one cracked block and multiple blown head gaskets) their was oil in the coolant. Only time I have experienced it the other way around was when the intake manifold gasket let go.
Old Jan 16, 2011 | 10:32 PM
PTBishop's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: A/T
I would agree, GM intake gaskets are notorious for going out, Also while you have the heads off, make sure they are true and straight. warped heads will allow coolant and oil to mix. Do the same with the intake where it meets up with the gasket. If you had a crack in the engine somewhere you would probably notice the milky mix in your coolant as well.
Old Jan 16, 2011 | 10:53 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
i would just do a complete top end renewal and it should fix the problem
Old Jan 17, 2011 | 12:59 AM
Guest
Guest
Posts: n/a
For the head gaskets, define "looks ok". I'd be more concerned with the block and the heads, there should be a nice and unbroken ring that is completely clean around the cylinder. If there is any point where its not, its leaking there. If you're getting a milkshake, that is probably where its coming from.
Old Jan 17, 2011 | 10:01 AM
Karasawa's Avatar
Car: KITT
all the rings on the gaskets are clean and unbroken, intake gaskets appear perfectly intacted, almost new since they're not very old.
Off topic question, are the lower bearings, cam, and timing chain the same in a 350 as a 305? Im asking because if i cant get this issue solved I still have the original 305 sitting that just needs new piston rings and valve seals, figured I would gut the 350 for its brand new parts and put on the 305.
Old Jan 17, 2011 | 01:35 PM
Guest
Guest
Posts: n/a
Yes those are the same but I would not reuse the bearings.
If you're going to try to fix it and have the heads surfaced, have the block done as well. More often than not, I've found on problem children that the block is not flat.
Old Feb 24, 2011 | 01:18 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
I,m in the same boat too.
(milk choc. in oil and car running like a 5 cylinder when idle hot)
But I did a compresion test. Numbers were:
Cylinders 1, 2, 3, 4 & 6 = 168 psi
Cylinder 5 = 118 psi
Then, I put 5ml oil in cyl. 5 and compresion was incremented in 14 psi only.
Then rings o.k. (the compresion tester was off with a bith water in it)
Put in a bit of compressed air by the spark plug hole and nothing happened.
Took that head gasket off, but it "looks ok" too. Only a bit of white deposits.
(Int man gasket "looks ok". It's 3 years old only).
I'm confused too. Where is the failure?.
What if I replace total top end gasket kit and problem remains the same?
I need the car for work, school transportation, wife's supermarket, children events, etc. etc.
I've headache with a new engine surprise.
Thanks for your ideas and opinnions,
Denis V.
Old Feb 24, 2011 | 01:42 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Just to add my two cents to the good information already given here, factory heads can crack between the intake and exhaust valve seats. This is hard to see but a pressure test will show it. The pressure test runs about $50-75 at most head shops. Also, there is no oil pressure in the crankcase itself, yet the coolant is at 15 psi. I have seen coolant in the oil and not oil in the coolant due to a cracked block. Generally though, i agree that the intake is the most common cause of coolant in oil.
Old Feb 24, 2011 | 02:04 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Don't forget the thread sealer on the bolts.
Don't ask why i'm saying that either I never done that I swear
Old Feb 24, 2011 | 02:16 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Ive often wondered whether the thread sealer is more so that the bolts don't freeze in place than to prevent coolant seepage. Taking a motor apart after 20 years of operation, you'll find the intake manifold & head bolts looking pretty sad. Imagine what they would look like without thread sealer.
Old Feb 24, 2011 | 02:27 PM
Engine: 350 for now
Transmission: wc t5
I actually forgot to put the sealer on once and I got coolant in the oil. took all the crap apart and put the sealer on and tada! no more coolant in the oil.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gixxer92
Apr 12, 2022 12:09 AM
bigjay89gta
Oct 15, 2015 08:04 AM
thekurlyone
Sep 30, 2015 12:54 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
