Service Engine Soon light - where is the DLC connector?
Old Feb 23, 2011 | 12:18 PM
CarloStu's Avatar
Car: 1988 Camaro IROC-Z
Engine: L98 350/5.7 TPI
Axle/Gears: 2.77
My SES light came on ('88 IROC-Z L98) a week or two ago when I had been out for a long drive to blow off the cobwebs after winter. It didn't come on again next time I drove, but today when I fired her up it came on again.
Before anyone says it, I have looked at: https://www.thirdgen.org/service-eng...ht-error-codes - Been reading a few threads on the subject and nobody seems to say exactly where the DLC connector is located? Granted, I haven't even looked yet, but that is because I have no idea what I am looking for - or where I should be looking for it... I am a noob, I know this.
I occasionally get a gurgling noise in my fuel tank after a drive and I usually just let the pressure out of the filler cap. I have read this can be the result of a vent or fuel pump issue and possibly the cause of the SES light?
Old Feb 23, 2011 | 12:23 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Re: Service Engine Soon light - where is the DLC connector?
The DLC connector is under the dash on the drivers side, near the fuse panel. Get the code first and that should give you a good idea where to look for the problem.
Old Feb 23, 2011 | 12:30 PM
CarloStu's Avatar
Axle/Gears: 2.77
Thanks G-reg I'll get my paper clip ready and check it out. :-)
Old Feb 23, 2011 | 01:29 PM
robertmoreno14's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Is there a tool to check the codes? i've heard that you can use a solid flattened wire to join the dlc connections to cause a (code flash)??? im new to f body's so dont laugh
Old Feb 23, 2011 | 01:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can use any standard OBD1 code reader, but why when a paperclip is free?
Old Feb 23, 2011 | 01:47 PM
Car: 1990 Camaro RS
Engine: 305 TBI
Free is good. lol if i do happen to (Aquire) a clip, what pins need to make contact to get the codes.
Old Feb 23, 2011 | 04:38 PM
CarloStu's Avatar
Axle/Gears: 2.77
The main TGO guide should explain most of it in the "DISPLAYING THE TROUBLE CODES" section:
But some people (myself included) didn't understand the flashing/blinking sequences at first. I found a similar thread where "itsMikey" explained it clearly:
Originally Posted by itsMikey
heres what ya do...
*blink (pause) *blink *blink = code 12
*blink *blink *blink (pause) *blink = code 31
got it?
So the first blink with a pause is a single or multiple of 10 and the next sequence of blinks are the digits (1-9).
You can see that whole thread here:
https://www.thirdgen.org/forums/tech...gine-soon.html
Old Apr 9, 2011 | 08:18 AM
CarloStu's Avatar
Axle/Gears: 2.77
Finally got round to checking my SES light code yesterday, thanks to my mate Stackofire who came round to show off his shiny just finished Z28.
Turns out its only showing code 12 over and over again... so why was the light coming on? Stacko asked me if the battery had been disconnected as the book also says this can wipe the code - nope, it has definitely not been disconnected since the light first came on.
Deck man
Jun 22, 2011 09:54 PM
FoxRodder
Feb 5, 2006 01:49 PM
chosen1
Northern California
Sep 23, 2005 08:29 PM
Dr.NickRiviera
South Central Region
Jan 21, 2005 10:19 AM
TPIMarow6.6
Nov 1, 2004 11:35 PM
