Engine stalls and shuts off at low PRM's
Old Mar 14, 2011 | 05:08 PM
ponchilaz's Avatar
Car: 1987 Camaro iroc z
Engine: 350 TPI 5.7L
Transmission: Automatic
I just bought my 1987 camaro iroz about a month and now my car stalls at low rpms and sometimes it shutsoff. What can i do to fix that problem?
is it a simple problem? expensive to fix?
thanks
Old Mar 14, 2011 | 05:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Engine stalls and shuts off at low PRM's
thanks
Could be any number of things. does it run fine if you drive it or act up all the time? Need to kjnow more about the car. Engine, fuel injection/carb, etc. etc.
Old Mar 14, 2011 | 06:08 PM
ponchilaz's Avatar
i have a v8 5.0 fuel inject.
The car runs fine while i drive it, when i stop at a stop light or stop sign or while i wait for a red light to change green, the car wants to die out but sometimes it does and sometimes it dosent.
also sometimes after i stop and then take off and gas pedal gets stuck so when i press down on it to get it unstuck the engine stalls for a couple seconds and revs fine and good take off......i heard it could be the throttle body of why the gas pedal gets stuck
Old Mar 15, 2011 | 08:59 PM
64elko's Avatar
Car: 64 elcamino
hello
my ride did the same thing i took the throttle body off and cleaned with throttle body cleaner,,open throttle butterflies an clean (wipe dry ) spry the linkage as well, it was ok after that.... just a thought ,,i am no expert...
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
