running way to hot
Car: 1985 iroc
running way to hot
i just finised rebuilding it and when i got it out and drove it it was running at almost 250 degrees. i have a 3 coar aluminum radiator in it, with aluminum heads, so im clue less why its so hot. any help would be appreciated thanks
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: running way to hot
Check these things:
1. Correct waterpump?
2. Air Dam in place?
3. Thermostat stuck shut, or even in place?
4. Fan working properly (If electric)?
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
If i'm not mistaken, dosen't a new rebuild or a new engine run hot for the 1st few miles? I have always been told not to run headers on a new or rebuilt engine for the brake in period because of how hot they run. if everything else if in working order it might be something to look in to.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Gauge correct? If it's not boiling over, it's not overheating. These gauges are usually far from accurate.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Im with camaronewbie on this one. The factory gauge is not reliable. Use an infared thermometer to verify temps at the radiator and thermostat housing. Check for thermostat openning by holding the top hose with your hand. You'll feel it swell and heat up when the t-stat opens. you'll also feel the radiator get hot and the fan(s) should come on soon after.
Car: 1992 RS
Engine: Carbed 350
So we're back to the basic questions not answered yet ...
1) air dam in place?
2) fans working?
3) thermostat working?
4) correct water pump in place and moving coolant?
5) this is the 350 in your sidebar?
6) carb or TPI?
7) what's timing set at?
8) single or dual fans?
9) stock fan wiring or aftermarket controller?
10) overheating in town, or on highway, or both?
so far all we know is that it's overheating - we need way more info. aluminum heads a radiator don't have anything to do with overheating.
2) fans working?
6) carb or TPI?
Car: 1985 iroc
the timing is at 8 degrees advanced
the water pump is fine
dual fans after market controled
its over heating in town and on the highway
its a .501 lift can with 244 duration on the int. and exh.
and its carburated
and its carburated
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
If not it's likely going to run rich and hot.
If it's been converted to carb the timing on your MECHANICAL, non-computer controlled distributor should be way more than 8 degrees advanced at idle. Retarded timing=hot.
Car: 87 IROC Z28
Engine: 355 cid TPI
So it's not just the gauge. I agree that 8 degrees is not enough lead for that cam. However, just in my own experience, I tend to find running more lead raises temp. I also find that running leaner raises temp. At any rate, whether you're running the factory carb or not, I would definitely get it on a gas machine and verify AFR. CO on that motor with no cat should be about 2.5-3% and HCs about 300-400ppm. If you can swing a wideband O2 that's even better. AFR should run about 12.5:1.
Has it run hot since you built it? Did you get the head gaskets right? Was the block boiled to remove all deposits from the water jackets? Does the coolant boil even when cold? That would be a head gasket failure. Check the cooling system, using the simple test I described above, to verify operation.
A lean motor will probably run hotter than a rich one though as the unburned fuel in a rich mixture will probably have a cooling effect. At least until it burns up in the exhaust stream.
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
