92 5.7 TPI EGR solenoid question
Old Mar 16, 2011 | 09:41 PM
colohusker's Avatar
Putting together a 92 z28 with the 5.7 TPI that someone had started an engine swap in. We reringed it and put new bearings in because it had a knock when we did have it powered up.
So, my question is, did the 92 5.7 TPI have an EGR solenoid? I've seen a couple of books and posts referencing it on a wiring diagram, but I've seen other references saying it doesn't. I do have a pigtail right next to the coil with nothing to plug it into, so I'm thinking that it's supposed to have one.
If it's supposed to have one, does anyone know a source or a GM part number for one, or will one off the caddy 4.9 or 4.6 engines work?
Thanks,
Scott
Old Mar 20, 2011 | 12:29 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: 92 5.7 TPI EGR solenoid question
yes it is supposed to have one. don't have a part number, but from my understanding, they are not available anymore. As for another one fitting, sounds reasonable to me if all the hook ups are the same.
Old Mar 20, 2011 | 08:55 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Any solenoid of that type will work as long as it is the N/O (normally open) type with the same connections.
Old Mar 21, 2011 | 06:24 AM
colohusker's Avatar
Thanks for the replies. I'm trying one from a 92 vette since it was a 5.7 tpi. I'll let you know what results I have once I get everything put back together.
Old Jul 18, 2011 | 11:13 PM
andresruiz91's Avatar
Hi guys I have a 91 5.7 TPI and my EGR solenoid is bad. :/ As stated above, they're not available anymore, so I was wondering if someone could tell me which cars EGR solenoids would work for mine, and possibly where to buy said part. Please help?
Old Jul 19, 2011 | 06:14 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
if you can get the GM production number, usually a 6 to 8 character numerical, i may be able to find you one.
Old Jul 19, 2011 | 07:41 AM
Not really sure where to find that number. :-/
1992rs/ss
Jan 31, 2025 05:10 PM
jklein337
Sep 19, 2018 06:23 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
