Help me decide on what engine to build
Old Apr 1, 2011 | 02:36 AM
SEMPERFIDELIS's Avatar
Car: 96 Firebird T-Top
Engine: 3.8L V6
Transmission: Automatic
Hey guys since Ive made my choice on what bodystyle I want to pick up for a roller project I need to decide what engine I want as Ill be having that built first so I have more time to find a good clean body to work with. My goal is 500-600hp, Budget would be in the $7,000 range. So what do you guys would think makes a unique build?
350
LS1
454
My goal is to have a somewhat unique swap that isnt being done all the time. If I chose the 350 it would most likely get blown. Both the 350 and 454 would be carb'd.
Old Apr 1, 2011 | 09:39 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Help me decide on what engine to build
Nothing about any of those is unique in any way.
Old Apr 1, 2011 | 09:44 AM
torque_is_good's Avatar
350
LS1
454
have you used the search feature? Your question is quite commonly asked by newbs.
if your goal is a 500HP-600HP engine then go buy one. Go to racingjunk.com and you can pick up an already built engine, put it on a stand and show everyone the 600HP engine.
When stating a goal, you need to state what the goal of the entire package is. I've seen lesser powered vehicles win races at the strip because it was a well built combination.
I do assume that this is a strip only build; correct? So, are you looking for low 12's, low 11's, high 10's ?
you then will get suggestions about weight reduction, suspension, drive train, tires and finally; engine.
Also, is there a particular class that you want to target to run?
If your track is 1/8 mile then you might want to consider spray vs FI.
Old Apr 1, 2011 | 05:07 PM
Engine: 3.8L V6
Actually a weekend street car. I wasnt looking for a unique engine per-say, but was more curious on which is swapped the least, or used the least. The end goal is a more all around car, the power is kind of overkill but being my first roller project, as apposed to buying a running car and modding, I want to make it a nice showpiece with wire-tucking etc. Obviously the drivetrain will be built to handle the power. 500-600 is just a starting number. I planned on picking an engine, then finding a good combo parts list for it and seeing where I land when the dust settles.
side note: sorry about not using the search, Im still getting used to sites that feature works on. The Firebird forum Im on for my DD has a horrible search lol.
Old Apr 1, 2011 | 05:16 PM
azfirebird's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7l
Transmission: 700r4 New Rebuilt 2011
Axle/Gears: 9 Bolt
also keep your eye on craigslist for someone who has built an engine and changes their mind and goes another route.
Old Apr 1, 2011 | 05:49 PM
Benjam88's Avatar
I would find an LQ4 or an LQ9 6.0 out of a newer GM truck. Cam it up, put some LS3 heads on it, a set of stainless works longtube headers and a carb intake. It would be pretty boss and dependable. And later if you want some more power you have room for expansion. Like a stroker kit.
Old Apr 2, 2011 | 02:20 AM
Engine: 3.8L V6
Actually doesnt sound like a bad idea. Thanks.
Old Apr 2, 2011 | 03:01 AM
Benjam88's Avatar
If you are gonna go the automatic route you can use a 700r4, all you will need is an adapter flex. The bolt pattern is VERY similar and is actually only one bolt hole that is different. You can have it drilled or just ignore it, it won't cause a problem.
http://www.jegs.com/p/JEGS-Performan...18379/10002/-1
This intake and MSD box will get you on the carb path. For some extra dough you can get a Victor JR carb intake as well. You will also need a TV bracket on your carb.
http://www.speedwaymotors.com/Edelbr...ign=GoogleBase
You will also need an F body oil pan (Ebay) and depending on what vehicle you get the motor out of, you might need to swap your accessory brackets (Again Ebay) If you want to go a cheaper route on the headers then find some 4th gen F body shorty headers.
Old Apr 2, 2011 | 03:41 AM
Engine: 3.8L V6
Thanks for the info, I was actually hoping to find a 5 or 6-speed to bolt up to what ever engine I use. I typically only like automatic in my DD's because of the amount of driving I do some days.
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
92projectcamaro
Aug 6, 2015 01:20 PM
