CUTTING OUT AT 2500 ISH
Old Apr 6, 2011 | 05:37 PM
whitesnake23's Avatar
Car: 92 Fierbird/77 K2500/01 serria
Engine: 350/ 3.1 / 5.3L
Transmission: 700R4/th400/4l60e
Axle/Gears: 2.33 REAR GEAR 9 bolt disc
HI I HAVE A 85 FIREBIRD TA HAD A 305 NOW HAS A 93 350 WITH THE TPI SWAPED FROM THE 305 THE CAR RUNS GOOD EXCEPT WHEN YOU HAMMER IT IT ACTS LIKE YOU TURN OFF THE KEY WHEN IT HITS 3000 AND UP IF YOU FEATHER IT YOU CAN GET 2800 BUT NO MATTER WHAT I DO I CANT GET IT TO RUN PAST THAT RPM IS IT TOO SMALL INJECTORS FUEL PRESSURE IS 35 WITH THE PRESSURE REG CONNECTED AND 42 WHEN ITS NOT BUT I AM LOST AS OF WHAT TO DO ANY HELP IS GREATLY THANKFULL!!
Old Apr 6, 2011 | 07:27 PM
njdsmer's Avatar
Re: CUTTING OUT AT 2500 ISH
It sounds like it may be your computer, throttle position sensor (most likely), egr valve/sol or your ignition control module.
Old Apr 7, 2011 | 11:15 AM
I JUST CHANGED THE INGITION CONTROL MOD YESTERDAY KEEP GETTING A CODE 44 WITCH IS LEAN EXHAUST
Old Apr 7, 2011 | 05:07 PM
njdsmer's Avatar
according to my obd2 guide it says "HO2S Bank 1 Sen 3 Heater Circuit High" which means your o2 sensor is bad. Bank 1 sensor 3 is which o2 sensor is the one that needs to be replaced.
Old Apr 10, 2011 | 09:41 AM
it only has one oxygen senser and i purchased a new one when i did the swap so ant other ideas
Old Apr 10, 2011 | 11:00 AM
njdsmer's Avatar
egr valve/sol or your computer is wrong for your car
Old Jul 13, 2011 | 09:49 AM
the computer is stock and i just replaced the tps sensor and it still does it does any one have anymore ideas i dont have any codes and it seems to depend on where i set the tps when it cuts out with the tps is set to the specified setting it cuts out out at 3000 so what is going on does any one know
Old Jul 20, 2011 | 03:00 PM
got it the fuel pump was generating sufficant pressure but was NOT genreating enough fule volume basicly we hooked a pressure gauge up and at idle i had 47 +- psi but when you increased the throttle or snaped it to wot the pressure droped to 20 psi because the engine was consuming more fuel than the pump could provide therefor starving the engine and thats why it would run at idle and 1/4 throttle and fell on its face at 2500 ish. thanks for everyones help
Old May 30, 2012 | 10:32 PM
delete
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
