Alternator
Old Apr 16, 2011 | 11:15 AM
Jaws031's Avatar
Car: 88 camaro
Alternator
want to change my alternator to get more amps. How do i find out how many my old one has
Old Apr 16, 2011 | 12:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Alternator
Autozone.com shows a stock replacement of 105 amps, so I'd say that's what you have.
Old Apr 17, 2011 | 12:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Alternator
When upgrading to a higher amp alternator, you need to keep it in the same series or it won't fit. Many of the higher amp alternators are physically larger and you'll need to change the mounting hardware.
Old Apr 17, 2011 | 07:07 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: Alternator
Powermaster makes a 140 amp model that is a direct fit. I've got one on my 87 IROC and it works great. Little on the pricey side though. You will need a 10 gauge charger wire also.
Steve
Old Apr 17, 2011 | 07:39 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Alternator
So true Alky.....................
If you want to move up from your stock cs-133 105 amp unit and go
to a cs/ad 144 150-160 amp unit your gonna have a size and fit issue
not to mention the cs-144s are $200+ for a re-man unit.
For a direct bolt in a Powermaster unit is the way to go !!!!!!!
OR..........Call arount to any local alternator re-build shops and see if they
can "pump up" your existing unit to 150-175 amps.
Old Apr 18, 2011 | 04:27 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: Alternator
I got one from ebay and the company was springhill alternator but it is a 230a cs-130 with a overdrive pulley and it has been keeping my two batteries charged and handles my stereo system just fine for 3 years now.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
