gas in oil pan
Old Apr 26, 2011 | 11:07 PM
ericg83z28's Avatar
gas in oil pan
hi guys i got a 355 sbc 2 piece seal, and its a new engine, the carb thats on it is a edlebrock 1406 camshaft is a 280H comp cam hydraulic flat tappet with estreet 64cc heads , stock fuel pump btw , the plugs are black how ever from carbon , any thing to check out?
thanks
Old Apr 26, 2011 | 11:15 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: gas in oil pan
Did you tune the carb per directions?
Mixture sounds very rich for plugs to have gas fouling.
Do an oil & filter change. Gas will wash out the bearings.
Is the fuel pump new?
(edit)
Make sure you have a good blue spark at the plugs. A yellow // orange spark is weak. A weak spark will also cause gas fouled plugs.
Old May 12, 2011 | 01:41 PM
ericg83z28's Avatar
Re: gas in oil pan
hi there the oil pump is from a previous engine but i changed the eddy 1406 stock metering springs to the silver heavier springs thinking that would solve it cuz of the longer duration cam but now it wont start , the engine has only really started maybe 4 times since rebuild and now it wont start , what is the procedure for the AFR ?
Old May 12, 2011 | 01:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: gas in oil pan
What fuel pressure are you running?
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
