Cam swap on the Horizon
Old Apr 27, 2011 | 01:23 PM
Killerz187's Avatar
Car: '91 Camaro RS T-Top
Engine: 383 Stroker
Transmission: Bulldog 700r-4
Before I start throwing money around, I'd like to ask if I can re-use some of the things on my motor. That way, I wouldn't have so much to buy.
Can I re-use the timing set, spring retainers, clips, springs (if they'll hold)?
They have, at most, 60 miles on them after the engine build.
Would I be safe in just buying the cam and lifter kit?
Old Apr 27, 2011 | 01:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Cam swap on the Horizon
You can reuse it all if you want, and if the springs are compatible with your new cam. If you have a roller cam now you can even reuse the lifters.
Old Apr 27, 2011 | 03:01 PM
Killerz187's Avatar
Engine: 383 Stroker
I don't know exactly what cam is in there, but I'm not going to take a chance on it and just get the lifters with the cam.
Thanks for the quick response, really appreciate it.
Old Apr 27, 2011 | 03:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you get a flat tappet cam and lifters, and then you find out that you have a factory roller cam in your block now, you'll need a new timing set.
Old Apr 27, 2011 | 03:12 PM
Killerz187's Avatar
Engine: 383 Stroker
I know that the block itself it a 72 casting, so I know that It's not a factory roller block.
Old Apr 27, 2011 | 03:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ok then, cam, lifters, gaskets, coolant, oil & oil filter.
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
