please help on ignition wireing my car is disabled!!!
Old May 2, 2011 | 01:30 AM
bjm1206's Avatar
Ahhh I finally did it I ripped out the hacked in MSD ignition box that the PO spliced into the ignition coil and distributor. However the problem is now I don't know what wire goes where. The big fat Pink wire I know goes to the wire loom I was able to match that one up. I do not know where the other 3 go. Coming off the coil There is a skinny pink wire next to a white wire, then there is a white wire with some sort of connector on the end of it next to the fat pink wire. The wires coming off the distributor are both white so I'm not sure where they go, somebody please help my 1990 IROC is now disabled and I wanna drive it.
Old May 3, 2011 | 10:55 AM
bjm1206's Avatar
Re: please help on ignition wireing my car is disabled!!!
please please can somebody look at their stock camaro and let me know what wire goes where
Old May 3, 2011 | 11:15 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On the diagram the wire marked TO IGN is the heavy pink, it is paired with the one that goes to the tach (white).
The pair that go between the coil and the module are pink & white. White going to the C terminal and pink going to the + terminal.
Note that within the coil the Tach lead and the C (on ICM) are tied together. Same for the pink wires, heavy pink is power to coil, which feeds through and provides power to ICM.
RBob.
Attached Thumbnails please help on ignition wireing my car is disabled!!!-tmp.jpg
Old May 3, 2011 | 11:40 AM
bjm1206's Avatar
Thank you very much I hope this takes care of my problem I need to order a new connector now cause the stock wire is now ripped away from the connector ahhh it is all screwed up, why do people do this to camaros... I mean have some respect
Old May 10, 2011 | 01:57 AM
bjm1206's Avatar
anybody have any idea where I could get the wire from coil to distributor at?
Old May 10, 2011 | 06:14 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Standard Motor Products makes the connectors. You just have to join them together. Try these part #'s:
S551
S562
S563
TX3A
on the "part number" section of this website:
http://eaccess.smpcorp.com/eCatalogs...?vehicle=22417
Any auto parts store on earth can either order a Standard part, or at least cross it and get what you need.
Old May 10, 2011 | 11:14 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Many TBI trucks and cars use that wire set. U-pull-it yard, hit the '87 - '92 vans and pickups. Also the same year Caprice's and the wagons. Get a spare one too as the wire sometimes breaks internally where it exits the coil connector.
RBOb.
Old May 11, 2011 | 12:22 AM
bjm1206's Avatar
RBOb.
hey thanks i will hit a couple up this weekend
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Sep 2, 2020 07:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
djmarch
Aug 9, 2015 05:27 PM
