not enought backpressure?
Old May 23, 2011 | 08:03 PM
Racca116's Avatar
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
im running a 355 with 1 5/8 headers, 2.5 in y pipe and 3 in the rest of the way. someone told me yesterday if i weld in a 6 in long section or 2 in pipe at the back of the y id see my torque curve jump up quite a bit. it sounds legit but im looking for other opinions
Old May 23, 2011 | 08:18 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
Re: not enought backpressure?
I would stop listening to that "someone" and do more research here regarding exhaust, etc.
CG
Old May 24, 2011 | 04:19 PM
Racca116's Avatar
Car: '85 Camaro Z28
so you dont think that its too open then?
Old May 24, 2011 | 04:24 PM
Twin_Turbo's Avatar
Old wives tale!! Backpressure is only used on 2 strokes to prevent over scavenging from pulling too much air/fuel out into the exhaust.
Old May 24, 2011 | 06:22 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
^ Wurd....
Old May 24, 2011 | 06:39 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
since you changed your exhaust, what kind if difference have you experienced? Did you lose low end torque? when i first bought my car it had no catback, just a dual ypipe. After i added a 2 1/4 catback and muffler the car performed totally different. It had a lot of low end torque. Without my catback it felt like it made more power in the higher rpm's, but definately less low end
Old May 24, 2011 | 06:42 PM
ninetyone's Avatar
Axle/Gears: 3:42
I mean 3" sounds a little big for what you are running. If your only mods are headers. I think you may benefit from that big of an exhaust after heads and intake swap.
Old May 24, 2011 | 06:43 PM
Shadow Z's Avatar
Car: Lots of 'em
I don't know how many people I've tried explaining this to. A loss or gain in torque or throttle response is not due to enough/too much backpressure. It's exhaust gas velocity. Too big and you'll slow down the flow, making the car feel laggy, and underpowered down low. Too small, you'll have excellent response since the gasses have no room to expand and cool, but not enough flow for up top in the RPM range.
This someone's thinking is odd. Back pressure kills power.
Old May 24, 2011 | 06:44 PM
ninetyone's Avatar
Axle/Gears: 3:42
Are you even running a muffler?
Shadow Z's Avatar
Car: Lots of 'em
Good question.
Old May 24, 2011 | 09:16 PM
Racca116's Avatar
Car: '85 Camaro Z28
im runnin a hooker aerochamber. also for further info, its got a comp extreme energy cam, fuelie heads and a full msd ignition. all my power is made up top anyways. it had a similar exaust setup when i bought the car, tho so idk what it felt like from stock to this. old system rusted out, only differance is the old headers had air tubes and the new ones have a slightly larger collector.
Old May 25, 2011 | 10:34 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
You will just be creating a choke-point if you follow that "someone's" advice. A 2 1/2 to 3 inch exhaust is totally fine for your application with the mods listed above, provided the combo works and has a good tune.
Old May 25, 2011 | 10:42 AM
ninetyone's Avatar
Axle/Gears: 3:42
I agree, with a carb car, play with your timing and fuel to get it where you like it performing.
Old May 25, 2011 | 05:52 PM
Racca116's Avatar
Car: '85 Camaro Z28
yeah thats where im at now. i been screwin with it for weeks and i cant get it right. i gotta throw in the new fuel pump i bought and im takin it to a dyno shop. edelbrock 1, racca 0 lol
formula_novice
Sep 5, 2015 03:58 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Drekken
Jan 9, 2002 09:01 PM
Joel Geerling
Dec 5, 2001 01:04 AM
I_Live_4_my_RS!!!
Nov 2, 2001 01:21 PM
