91 tpi looses power at normal operating temp
I have a 91 tpi z28 when you first start it runs great a minor miss at idle thats it it starts great and accelerates fine. 5-10 minutes of running it idles like crap and when tyou go to accelerate it is a total dog. The car has a new fuel pump and filter fuel pressure regulator. plugs wires and cap rotor. It runs great cold.
Engine: 4++,350 & 305 CIs
Re: 91 tpi looses power at normal operating temp
Check coil output, ign module and pickup coil
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
When it gets to regular operating temp the ECM begins to use the O2 sensor to adjust the air/fuel ratios. Are you getting any O2 sensor codes? Try disconnecting the O2 sensor and see how it runs when warm.
Car: 1992 Camaro RS
Between 190 and 220 I think. Depends on the car and setup etc.
Car: 1992 Camaro
I'm new here and have the same problems with my 92 305, if it runs better with the o2 sensor removed, can it be left out?
Iroc8t8
May 4, 2026 08:09 PM
Sanjay
Aug 12, 2015 03:41 PM
