valve stem seals?
Old Jun 5, 2011 | 07:26 PM
dustinxix's Avatar
Car: 1988 firebird formula
Engine: 5.7 TPI :)
Transmission: Auto :(
Axle/Gears: 9 bolt LSD
valve stem seals?
well figured out i need to replace my valve stem seals, but im getting ready to move. my question is do you guys think itd be safe to drive about 1000 miles like that? its not that bad just a small blue puff of smoke on startup.
Old Jun 5, 2011 | 07:48 PM
1fast5.7's Avatar
Car: 89 T/A
Engine: 305 soon to be LS1
Transmission: 5 speed soon to be 6 speed
Axle/Gears: stock
Re: valve stem seals?
Youll be fine. As the motor heats up the stems grow in the seals. And seal better. Youll be fine!
Old Jun 5, 2011 | 08:10 PM
dustinxix's Avatar
Engine: 5.7 TPI :)
awesome! thanks for the input! i was hoping i could just wait till i got down there to do the seals lol thanks man!
Old Jun 5, 2011 | 08:36 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
You never have to change them if you don't mind the startup puff.
Old Jun 5, 2011 | 11:49 PM
1fast5.7's Avatar
Car: 89 T/A
Axle/Gears: stock
technically hes right. oil only gets past the seals when its cold and only a verry small amount. you can drive the car for the rest of its life and not worry about em. and no problem man.
Old Jun 9, 2011 | 01:31 AM
SeanO23's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: Posi 3.27
i have this problem as well. i was wondering. if the seals arent warmed up, like when i first start the car, could this make it harder for the car to start?
my car starts fine if it runs for a couple minutes but when i go to it in the morning it doesnt like to start instantly
Old Jun 9, 2011 | 02:03 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Valve Seals no bad fuel check valve or leaky injector yes its allowing fuel to empty the system and the prime at key on is not effective enough to refill it
Old Jul 10, 2011 | 09:40 PM
sabresfan's Avatar
Car: Looking for a new thirdgen
Engine: hopefully a 5.7L 350
ive got the same issue going on as well. my car has been running pretty crappy and i was told it was valve seals in cylinder 1 & 7 that are bad. i need to swap out the spark plugs every couple weeks to keep it running ok and it burns up oil and leaks oil pretty quickly. when i step on the gas it wants to stall but from the info in the thread i feel like ive got a bigger problem. any ideas?
Old Jul 11, 2011 | 07:22 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
sabresfan:
Is it blowing smoke all the time, or just on startup? When was the last tuneup?
Old Jul 11, 2011 | 07:31 AM
sabresfan's Avatar
it does on start up and once in a while driving it. i had it tuned up a month ago
Old Jul 11, 2011 | 07:55 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Probably more leak than burn then, have to track down the leaks. Are the plugs fouled with oil (seals or blowby problem), or soot (mixture problem)? Any oil in the intake?
Old Jul 11, 2011 | 07:58 AM
sabresfan's Avatar
yea the plugs are fouled with oil when i take them out
Old Jul 11, 2011 | 08:58 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Ok, possibilities off the top of my head:
* Valve seals as mentioned.
* Excessive blowby forcing oil back thru the pcv valve, into the intake.
* Intake gaskets leaking from inside the valley.
* Non-taper seat plugs, or plugs loose, letting oil wick down from leaky valve covers.
Bubbajones_ya
Jul 6, 2024 08:32 PM
355tpipickup
Sep 13, 2015 11:35 PM
bamaboy0323
Sep 12, 2015 07:14 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
