91 bird 3.1 slugish,chugs,stalls,eats gas
Car: 1991 pontiac firebird
Engine: 3.1
Transmission: 700r
ok i bought this car 2 months ago and it would not start..well after playing arould i found out if i pull the bank2 injec fuse it will start run and idol but lacks much power...like i cant even powerbrake it .and if i have it running and put the bank2 fuse back in it will slowly sputter to a stall ..and this thing eats gas bad i burned 1/4 tank just at a 15min idol with some reving but like 3000rpm max..ok here is what i have done i pulled the timeing cover marks were good chain was good but i had to replace the tentioner thats all good now...i set the timeing all the injecters are in range..new fuel filter,fuel pressure is 42 .....and i know this is nuts but i tryed to get codes and guess what it dont have a mil...crazy yes but i pulled the cluster to see if it was a bad bulb and theres not even a spot for a mil..so im stumped..but today i got on a mission to look at other things and with some reading seen it could be the tps so i played with that and im not sure what to look for and my dang meter is brokin and there is no adjusting it....oh the last owner replaced the ecm also....but any help would be great i want to drive this car b4 it snows lol
Car: check
Engine: check
Transmission: check
Re: 91 bird 3.1 slugish,chugs,stalls,eats gas
Replace the fuel injectors. Just because they measure in range doesn't mean that they are still good. You proved it was the injectors by pulling fuse INJ2 and the engine then starts.
Get a set of Bosch reman from someone such as South Bay Injectors:
http://www.southbayfuelinjectors.com/
First set under "Most Popular Items", hmm...
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Forgot, our cars don't have a MIL light, look for a place that has SES (maybe CEL, although I'm more inclined to say SES).
RBob.
RBob.
Engine: 3.1
Transmission: 700r
ok i have codes now....i got 12 like normal and 22 and 34....i know 34 is the tps and 22 says map or maf dapending engine but i dont know what one or were it is ...im thinking the airfilter housing?
Car: check
Engine: check
Transmission: check
The TPS isn't adjustable and doesn't need to be. The ECM auto-zeros it.
Code 34 if MAP low. This is an uncommon code, and I would suspect that you had unplugged the connector to it while the engine was running. Same as the TPS, that will set the low code.
You may want to do an idle relearn once the new injectors are installed. Doing this will also clear the codes. Search the V6 board here with my username as the poster and "idle learn." There are several threads that describe it. A nuisance but easy to do.
If you don't do an idle learn after the ECM loses power the engine will stumble, stutter, spit and stall. And you will want to disconnect the battery while swapping injectors, with all that fuel around.
RBob.
Engine: 3.1
Transmission: 700r
i did unplug the tps well it was running but as for anything else i have left it alone ill look up your other post and see if it helps..thanks
Engine: 3.1
Transmission: 700r
ok i did the idle learn to a T i did it with and with out the inj2 fues...i put that fues in b4 i did all this and it ran and would idol but would not rev over 3000rpm so i did the idol iearn now if i just tap the gas it stalls but it spits and sputters and will idol after a few but now i have ses light fixed it pops on so i checked the codes and now there is no 22 or 34 but there is a 33...i really dont have the money for new injecters so i want to try all other roads b4 i get to that point
Car: check
Engine: check
Transmission: check
RBob.
Car: check
Engine: check
Transmission: check
Engine: 3.1
Transmission: 700r
thers that damn word again..injectors...lol..guess its time to check ebay and amazon..i just wish i could buy a kit to rebuild mine but noooooo ...stupid FI cars lol the G bodys keep calling me back
Car: check
Engine: check
Transmission: check
Once the coils start to short the ECM can't properly drive them. With only one driver in the ECM all of the cylinders suffer.
RBob.
RBob is absolutely correct. To my knowledge there aren't any companies out there that replace fuel injector coils. Unfortunately the multecs short out because the coil is exposed to the fuel, so over time the coils get damaged. Not sure what your budget is, but all tgo members receive a 10% discount on all injectors with promo code tg11. If we can help you in any way please do not hesitate to contact us.
516-492-6504
516-492-6504
Engine: 3.1
Transmission: 700r
tell ya what southbay you want to help me out ..sponsor me ..send me some big a$$ stickers and injecters and hundreds of people can see your rolling billbord at my local ihra track when im stompin ricers lol and mabey even at the ihra nationals
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
