very intelligent help needed please!!!
Old Jun 30, 2011 | 09:23 PM
Fred meredith's Avatar
Car: 91 Z28
Engine: 350TPI
Transmission: 700R IThink
Axle/Gears: 323
Replaced all sensors,fuel pump,ign.module,pickup coil,Ecm., and car still won't. Run properly. Hard to start, misses dies and wont start back.Can pour gas in intake and will start back.Wont accellerate properly bogs
under acceleration ,surges and dies ,noid light dim,this normal? Any suggestions?
Old Jun 30, 2011 | 09:32 PM
MrPink's Avatar
Car: 1991 Pontiac Trans Am
Engine: 305 TPI 5.0L
Re: very intelligent help needed please!!!
The bogs under acceleration and surging/dying sounds like a bad Cat. convertor. Could also be starter,alternator. anyone else?
Old Jun 30, 2011 | 09:38 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Exhhaust cut before cat but after o2 sensors
Old Jun 30, 2011 | 09:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What's your fuel pressure?
Old Jun 30, 2011 | 09:52 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
45psi
Old Jun 30, 2011 | 11:33 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Does it hold that when you rev the engine. Also, whats the voltage at the injectors? Should have +12V. Its also possible that its a ground issue at teh ECM if the 'noid light doesnt light to the usual brightness that it should on +12V. The grounds carry the current needed to run the injectors as theyre negatively switched. Check the grounds on the back of the heads to be sure theyre clean and tight.
Old Jun 30, 2011 | 11:49 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
is the fuel presure being measure before or after the filter?
Old Jul 1, 2011 | 09:09 AM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Pressure test at fuel rail, grounds tight,car will sometimes run fine for a few min. Then just shut off like u turn off the key.then not start back pour gas in intake and start back maybe run maybe just multilingual it Burns that fuel.
Old Jul 1, 2011 | 09:33 AM
conlinj's Avatar
Bad injectors? Bad ecu? I've had similars problems with both my cars. My 89 firebird ended up having bad injectors, my 86 camaro had a bad ecu. What do your injectors ohm out to?
Old Jul 1, 2011 | 04:58 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Haven't ohm'd.injectors but runs fine sometimes so don't think its injectors,thinking maybe vats
Old Jul 2, 2011 | 08:06 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
change your fuel filter?
Old Jul 2, 2011 | 11:32 AM
conlinj's Avatar
It could be the injectors still, on my firebird it would run fine for a while once it was started, then for no reason would idle erraticly and have no power. It only takes a few minutes to do and then you can definitly rule them out.
-Jim
Old Jul 2, 2011 | 12:27 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Have changed fuel filter, changing oil sending unit today, no acceleration now at all was doing this previously but straightened out for awoke who knows? Not giving up yet appreciate the feedback. Maybe a chance yet!
Old Jul 2, 2011 | 09:25 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
No luck looking for more suggestions.
Old Jul 2, 2011 | 09:52 PM
ninetyone's Avatar
Axle/Gears: 3:42
What is the ohm reading of all your injectors? Also, another member on here told me that when you first turn the key on (not starting) that the ses light should blink once very fast and then turn solid. This indicates the prom is still good. I would not rule out a bad ecm tho still. Did you buy it used or new?
Old Jul 2, 2011 | 10:37 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Tried another Ecu. from another vehicle same response haven't ohms injectors. Yet,no vom will get one soon runs fine until u try to throttle or warms up but still misses at idle this is a new occurrence.
Old Jul 3, 2011 | 02:35 AM
ThunderODB's Avatar
Car: `89 IROC-Z Convertible
Engine: TPI 305
Sounds like EGR issues to me.
This is from the Haynes manual
.....Too much EGR flow weakens combustion, causing the engine to run roughly or stall. During cold operation it may cause the engine to stop after a cold start. At idle, excessive EGR flow may cause the engine to run roughly or stop after decelerating. Too much EGR flow while cruising may cause the engine to surge.
Too little or no EGR flow allows combustion temperatures to get too high during acceleration and load conditions. The result can be spark knock (detonation), engine overheating and emission test failure.
If you have the Haynes manual this can be found on page 6-11.
I am currently trying to get my `89 IROC convertible running, I just bought it for $4000 and it hasnt run in 5 years. Its only got 67k miles and is in pretty good shape cosmetically. However, the wiring is in pretty rough shape in places due to a rodent problem in the previous owner's garage.
I have to try to find the wires that go to the EGR solenoid (located behind at the rear of the intake between the distributor and the coil, has several vacuum lines and a 2-wire plug). I have the plug with about 3" of wire, but cant find where they disappear into the loom. Anyway, I would check the EGR system if it were me, that sounds like the issues that you are having.... Check the referenced page in the Haynes if you have one, if not, I can type out the troubleshooting steps for you.
Old Jul 3, 2011 | 03:37 AM
luvmy64's Avatar
Ignition control module. Just throwin it out there.
Old Jul 4, 2011 | 09:04 AM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Almost having the same problem here. Rebuilt engine and went to fire it up yesterday w/ nothing. Checked plugs, timing and wire layout many times. Plenty of spark. Car will run fine if you stand there with a bottle of starter fluid and feed the pleum. SES light does not flash when key is turned. I am going to go check the injector voltage and ohms and see what the deal is.
Old Jul 4, 2011 | 09:20 AM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Good voltage to fuel injectors, will start and run until it goes to open. Loop. Or closed loop whichever one it is sucking extreme amounts of air through Iac._
Old Jul 4, 2011 | 10:00 AM
Keoman's Avatar
Just went out and checked the voltage and ohm load on my injectors. 12.8 Volts on both the leads and 2.8-3.0 Ohms a piece.
Tried to manually pull up the SES light by connecting pins 5 & 6 and the fans turn on when the circuit is closed... weird... still no SES light.
A side note, the IAC motor does absolutly nothing when the key is turned. IIRC, it is supposed to extend completly to maxed out position when the key is turned.
Hey fred, at least yours has got some sort of life to it!
Good luck.
Old Jul 4, 2011 | 01:40 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Yah
Yah about two ft at a time and then it dies. Check your emc grounds and your engine grounds maybe a solution they all should be at the back of the engine check body ground to hope it helps good luck! !!
Old Jul 4, 2011 | 02:51 PM
ninetyone's Avatar
Axle/Gears: 3:42
Good luck.
Your injector ohm readings should read something like 0.015 and if you have any that are like 0.003 , then there is your bad injector.http://www.youtube.com/watch?v=_g8PdrT0MCU
Old Jul 4, 2011 | 05:16 PM
WhiteRS91's Avatar
Car: '91 RS Camaro
Engine: 5.7L Fuel Injected V8 (B4C package)
Transmission: 4-speed auto
Axle/Gears: 3:23
I have a '91 RS Camaro with the B4C police package, 5.7L 350cu V8
and
I have the SAME EXACT problem. I've done everything that you've listed, all the replaced parts etc.... with the exception of the ign.module...yet.
I also thought that it could be a bad relay(s) in the fuel line, or bad injectors.
also, when you start up cold, and the engine starts to warm up, does your oil pressure drop? Mine has been doing so and its nerve racking.
from a cold start, sitting overnight, its fine, runnin about 50psi. but as it warms up, its drops to barely 10.
and then it starts to bog and eventually will die out.
IF YOU FOUND a solution to your problem, please for the love of god, let me know, because i may have a similar, if not the same problem.
Old Jul 4, 2011 | 06:16 PM
ninetyone's Avatar
Axle/Gears: 3:42
I am telling you that you have bad injector some where man. Check it out to be sure.
Old Jul 4, 2011 | 07:21 PM
conlinj's Avatar
injectors should ohm out around 16. If they are around 3 they are bad. If you see 0.015, you have it on the wrong setting on the meter not a big deal though just move the decimal in your head (15)
-Jim
Old Jul 4, 2011 | 08:08 PM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Any of you guys tried checking fuel pressure while under load, could be a weak pump, had all those problems with my Fiero right after I bought it, my brother had replaced the pump for the PO, so I didn't think it was the problem. Keoman, you have no SES light at all??
Old Jul 4, 2011 | 11:06 PM
Keoman's Avatar
I'll check them again and make sure I was using the meter right. 3 ohms just doesnt sound right. (probably because its not..)
I wiggled the ECM and other random computer boxes around on the car and the SES light started working and the car started kicking over... bad ground i assume, or connection some where.
I just have to adjust the rockers.. the car is running like **** timed anywhere.
Old Jul 5, 2011 | 01:58 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
The tps could also cause this problem. If your tps has a dead spot or is way off on the voltage output you car could be compinsating for a wot condition that is not actually happening. more or less your car thinks your foot is to the floor so it's sucking air for that, when your actually at idle or half throttle . check the voltage. .54v closed and should have a steady and consistant rise in voltage as you open the throttle. (key on engine off)
This happend to my car. If I held the throttle to keep the car at about 1500 rpm the car would purrr. but if I let off the throttle or pushed the pedal down anymore it would chugg and die within a few seconds. Turned out the voltage output from the tps was all over the place. put in new tps and bingo.
Old Jul 5, 2011 | 04:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
FYI, BD1 and BD12 on your ecm are grounds. GE7 is your SES light.
Old Jul 5, 2011 | 04:45 PM
ninetyone's Avatar
Axle/Gears: 3:42
Also BC16 is battery voltage. I would test these with your meter. You need to look up the procedure for testing a ground if you dont already know.
Old Jul 5, 2011 | 07:08 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
New pump, good pressure, new tps, fixing to disable vats will let y'all know the outcome, thanks for the input keep it coming,
Fred
Old Jul 9, 2011 | 05:30 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Hey man ohm'd fuel injectors and got several different numbers just wondering what's the limits on these injectors seems like u have already been through this.
Old Jul 9, 2011 | 05:45 PM
Car: 91 Z28
Engine: 350TPI
Axle/Gears: 323
Thanks ninteyone had five bad injectors ,no wonder it ran like crap just glad to have people like u on here and somewhere to go for help Thanks a million! !!!
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
