Suggested Reading for 1st Timer
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
I've decided to tackle my first top end rebuild. I know how everything works together, just not the best idea of how to make it work
Any recommendations/suggestions for good reading material that gives visual step by steps?
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: Suggested Reading for 1st Timer
How to Rebuild Your Small Block Chevy by David Vizard
Your haynes service manual will help more specificaly.
Just tackled mine but I am having some issues after ward.
https://www.thirdgen.org/forums/tech...ml#post4970655
Engine: L69
Transmission: A4
Haha, I think I've been reading these since 2004. I can fix most everything else on the car, just never started taking engine stuff apart..... It's sad, I know...
I have the factory service manual, Haynes, and Chilton.
Keoman, thanks for the book
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
There's a lot of good info on here, Speed, Yellowbullet, etc. I look at just about every forum there is every day. Inbetween all the opinions and theories on what MIGHT work, there's usually some good facts in there if you dig deep enough.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
what do you call a "top end rebuild"?
how many miles?
Since you are pulling the heads, you'll probably see a nice ridge on the top of the cylinders. It will then be when you decide to yank it and send it out for a true rebuild getting machine work done. If it's high miles, forget trying to ream it and just have it bored/honed
Engine: L69
Transmission: A4
how many miles?
how many miles?
The thing I have liked most about that book by David Vizard is how much detail he goes into actually explaint how to test your components to see if they REALLY need to be touched. From his standpoint, seems like he thinks a lot of people mess with things that are really fine for daily driving.
