problem...
Old Jul 8, 2011 | 03:06 PM
shanep1991's Avatar
problem...
i just switched from a v6 to a v8, i put the v8 in the car and noticed this, how do i fix this? i dont want to take the engine out, is there a way i can just block it off and not use it? ill put my oil pressure sending unit somewhere else
Old Jul 8, 2011 | 03:08 PM
Guest
Guest
Posts: n/a
Re: problem...
You must get an ease-out and back that out of there. If you then want to plug it, that's up to you.
Old Jul 8, 2011 | 03:15 PM
shanep1991's Avatar
Re: problem...
i didnt even think of an easy out, idk why lol thanks alot, ill do that
Old Jul 8, 2011 | 03:17 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: problem...
Yep an easy out should take care of that without a problem. If you dont have one you might be able to rent or use one from Auto Zone or another parts store. That's not a rock in your lifter valley is it? Good luck!!
Mark.
Old Jul 8, 2011 | 03:39 PM
shanep1991's Avatar
Re: problem...
it is lol i havent got to cleanin it out yet
Old Jul 8, 2011 | 06:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: problem...
Hope none of those rocks went down the oil passages!
barbiek9
Sep 3, 2002 04:24 PM
FLYNLOW92rs
Aug 30, 2002 12:17 AM
Philou
Aug 18, 2002 01:29 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
