CAR WON"T START...HELP!!!
Old Jul 8, 2011 | 09:29 PM
CamaroLove45's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I have a 92 camaro...I went out to start it and it randomly wouldn't start it hasn't started in over a month..Replace wires, plugs, distributor cap, coil, starter and altenator is fine.ANY ideas on what would cause it to randomly stop starting. I have also tried to jump start it and that doesn't work either..Also it sounds like it wants to start but doesn't
Old Jul 9, 2011 | 12:14 AM
jbmillenium's Avatar
Car: 91 ws6
Engine: tpi 350
Re: CAR WON"T START...HELP!!!
check your fuel pressure at the rail, also do you hear your fuel pump priming?
Old Jul 9, 2011 | 12:20 AM
Car: 91 ws6
Engine: tpi 350
and check your injectors, thats what mine turned out to be, had 5 bad injectors and it wouldnt start at all, replaced and started.
Old Jul 9, 2011 | 11:58 AM
Car: 1992 Camaro RS
Engine: 3.1 V6
yes my fuel pump is running
Old Jul 9, 2011 | 12:12 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Battery, cables, and terminals ok?
Old Jul 9, 2011 | 03:13 PM
Car: 91 ws6
Engine: tpi 350
when i purchased mine you could hear the pump prime but had no fuel pressure at the rail, turns out one of the hoses in the tank cracked and was just spitting gas back into the tank. might want to check the pressure
Old Jul 9, 2011 | 10:05 PM
Car: 1992 Camaro RS
Engine: 3.1 V6
the battery was alittle dead but we were even jumping the car and it wasn't starting....and i'll look at the fuel lines
Its cranking just not getting fire
Old Jul 9, 2011 | 10:09 PM
Chrisj1123's Avatar
Car: 87 Camaro LT
Engine: Carb. 305
Transmission: 700-R4
Try the ingnition module. That turned out to be the problem with my 87 with similar symptoms.
Old Jul 14, 2011 | 10:25 AM
Car: 1992 Camaro RS
Engine: 3.1 V6
it was the ingnition module thanks =)
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
