1989 CAMARO
Old Jul 22, 2011 | 09:07 AM
JAMESPINNER's Avatar
Car: WORKING ON 1989 CAMARO
Transmission: 700-R4
1989 CAMARO
CAR WILL NOT START UNLESS I PUT A COUPLE DROP OF GAS IN THROTTLE BODY. HAVE NO DTC. ONCE STARTED AND RUNNING RUNS GREAT GREAT OIL PRESSURE 3O TO 35 PSI. ITS A 5.7 L. ITS SUPPOSE TO HAVE A NEW FUEL PUMP. WHAT IS THE RESISTANCE VALUE SUPPOSE TO BE ON SENDING UNIT. CANT FIND OUT NO WHERE IN MY HAYNES MANUAL. ONE OLD POST SAID SENDING UNIT COULD BE FAULTY EVEN THOUGH I SHOW GOOD OIL PRESSURE SO FIGURED I WOULD TEST FOR THE HECK OF IT. BUT DONT KNOW WHAT RESISTANCE I SHOULD HAVE. ANY HELP WOULD BE GREATLY APPRECIATED.
Old Jul 22, 2011 | 11:33 AM
Guest
Guest
Posts: n/a
Re: 1989 CAMARO
If it runs fine once you do get it started, then I'd stop playing with the pump / sender.
Did '89 have the 9th injector for cold-start? If so, that may be bad. Otherwise, maybe it's the oil pressure switch?
Old Jul 22, 2011 | 11:35 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 1989 CAMARO
Does the pump prime when you turn the key without starting the engine?
Old Jul 22, 2011 | 01:46 PM
Re: 1989 CAMARO
I DO NOT HEAR THE PUMP RUN WHEN I TURN THE SWITCH ON HOW EVER AS SOON AS I EAT LUNCH I'M GOING OUT TO MY SHOP AND HOOK UP A FUEL PRESSURE GAUGE AND SEE WHAT'S HAPPENING THERE. BUT I DON'T SEE HOW THE FUELPUMP COULD BE BAD CAUSE I WENT ON A 40 MILE ROUND TRIP WITH OUT TURNING IT OFF OF COURSE PLUS HAD A LITTLE BOTTLE OF GAS WITH ME.
Old Jul 22, 2011 | 01:47 PM
Re: 1989 CAMARO
IT HAS TWO INJECTORS ON TOP OF THROTTLE BODY.
Old Jul 22, 2011 | 02:16 PM
Guest
Guest
Posts: n/a
Re: 1989 CAMARO
Well, then this is your own fault. In '89, the 5.7L was TPI, the TBI was 5.0L, you failed to specify that it's a swap. Or it's not really a 350. It's not uncommon for people to call a 305 a 350 just because they look the same.
Old Jul 22, 2011 | 02:21 PM
Re: 1989 CAMARO
I JUST BOUGHT THE CAR DID NOT DO THE SWAP. THEY SAID A 5.7 WAS PUT IN STILL NOT 100%SURE I CAN NOT GET TO THE NUMBERS ON THE BLOCK .MAN SAID IT WAS A CRATE ENGINE FROM CAR QUEST.
Old Jul 22, 2011 | 02:32 PM
Re: 1989 CAMARO
THE ONLY #'S I HAVE BEEN ABLE TO GET TO IS 627 ON THE BOTTOM OF BLOCK AND ON THE MANIFOLD ....W5....GM....14102182 DON'T CARE THAT MUCH IF IT IS A 350 OR 305 EXCEPT FOR BUYING PARTS AND IT RUNNING GOOD.. IT HAS PLENTY OF POWER AND JUST LOVE MY CAR.
Old Jul 22, 2011 | 03:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 1989 CAMARO
Check the fuel pump relay.
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
