What's the best head for a 305
Car: 1986 Yellow Iroc-Z
What the best flowing heads the comes stock on a car that will fit a 305 tpi. Or is there a better top end that I can put on a I can put on the car?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What's the best head for a 305
For stock heads, there aren't much better than the ones it came with.
Guest
Posts: n/a
Not BS, but not good value for 305s, either. You have to mill them a lot, you have to swap the lower intake manifold, the exhaust side needs help...
For about the same money, you could do the TFS 175 heads, if you're planning on keeping the stock LIM, with porting.
But your 081s can be milled, cut for bigger valves, ported, and will perform nearly as well as the other 2 options, for much less cost.
Engine: 383 Carb
Transmission: 4L60
Ya they do not need to to be stock for the camaro just stock for a car or truck but I would like to keep my tpi.
What about the Trick Flow 305 heads? They are about the only "performance" 305 head on the market that I'm ware of. They have the right sized chambers so no milling is required to maintain the compression ratio. And the cost would probably be less than a Vortec swap (when you factor in the extra ~$400 they charge for a Vortec TPI baseplate). Heck, they're even 50 state emissions legal:
http://www.trickflow.com/egnsearch.a...7&autoview=sku
No you can't find the vortec tpi intake on a car unless it was installed with the heads. Vortec heads came on a truck engine and tpi was long gone from production vehicles by then. If you want a tpi vortec intake be prepared to pay 400+. I would got the TFS 305 heads if anything.
ambainb
Apr 25, 2016 09:21 PM
