Can't Install Pilot Bearing?
Old Jul 30, 2011 | 08:22 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am trying to install my new pilot bearing from Fortes parts for my TKO 600 and it will not go in all the way. It has about 1/4 inch until it sits flush with the crankshaft. Any ideas?
Old Jul 30, 2011 | 09:08 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
Re: Can't Install Pilot Bearing?
Did you get the right one? Seems to me there's an 'extended' one for LS1 transmissions or something...don't recall.
Old Jul 30, 2011 | 09:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I have the one that Forte's parts supplies with their TKO 600 kit.
Old Jul 31, 2011 | 07:16 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Are they different for 1 and 2 piece rear main seal crankshaft?
Old Jul 31, 2011 | 08:00 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Flush with the bottom of the crank hole, or flush with the top of the crank hole/crank flange? I've always done mine flush with the top of the crank hole.
I just did mine a couple weeks back, and I seem to recall the last 1/4 or so being the hardest. I needed a bigger BFH to achieve the same amount of movement per blow. Makes sense, though, you are fighting that much more friction after each blow that gets it in there deeper.
Old Jul 31, 2011 | 08:20 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am trying to get it flush with the end of the crankshaft.
Old Jul 31, 2011 | 09:36 AM
Should look roughly like this when installed.
Should be slightly less tall than its diameter. If it's taller than that, you have the wrong one. If it's the right one, use more force. I use a fairly massive BFH and a brass drift that's about 1¼" diameter.
Old Jul 31, 2011 | 11:51 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well mine definetly isn't that far in yet. I am using a mini sledge hammer and a socket on an extension and I can't hit it in any more. I tried using the grease method to pull it back out and it wouldn't even come out.
Old Jul 31, 2011 | 12:59 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
I believe to get these things in and out you have to use at a minimum 38 curse words... one thing you can do is measure the depth of the hole and height of the bushing. Good luck!
anesthes
Mar 10, 2016 10:35 PM
red90IROCls1
Aug 25, 2015 06:56 AM
gwade12
Aug 8, 2015 08:17 AM
rsrmoore
Aug 7, 2015 08:44 PM
