A/C help
Old Aug 16, 2011 | 01:29 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
A/C help
Ok, so when I first got my camaro a few months ago, the A/C was only cold on days that it wasnt very hot, but if it was hot, it just blew out air, not hot air or cold air, just mid temp air. Then my radiator broke, so I replaced it along with the hoses and flushed it all out, and pulled all the leaves and trash out from between the radiator and whatever that other thing behind it is (also looks like a radiator, but what does it do?). After I replaced that, 2 months ago, the A/C was very cold EVERY day, not matter how hot it was outside, and now all of a sudden, it's back to how it was when I bought it, except working a lot less, and the only other work I did was remove the injector pods and replace the o-rings, gaskets, supports and filters, so why is the A/C not working again? Thanks for any help guys
Old Aug 16, 2011 | 01:37 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: A/C help
did you check to see if there is stuff between the condenser(the thing that looks like a radiator) and radiator again? or you may be leaking freon
in simple terms, the condenser removes heat from the freon in the a/c system, if you want a full explanation on an a/c system I'll do my best but not at 1:45am
Old Aug 16, 2011 | 01:53 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: A/C help
Yea, I thought that was just another radiator for the a/c lines, I'll check to see if it's clogged up again but it shouldn't be, and it's 2:52 a.m. here haha
Old Aug 16, 2011 | 07:06 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: A/C help
either your fan isnt working (you'd also see overheating) or something in the a/c system has failed. pop the hood and identify the a/c compressor. with engine running and a/c on check to see if the compressor clutch is engaging. if it is not, then your either low on freon (very likely) or have some power problem (not as likely). If your low on freon you have a leak. and most likely it is from the compressor or some o-ring somewhere. a rock may have kicked up and knicked the condenser assembly. my
Old Aug 16, 2011 | 10:09 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: A/C help
Im not sure if it's the freon tho because it did work for a while
Old Aug 17, 2011 | 11:18 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: A/C help
Yes. But maybe you fixed one problem. and something else failed. mechanical parts can fail at anytime.
Old Aug 17, 2011 | 01:47 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: A/C help
Why does the clutch look like? Is it on the big metal thing that sweats with the ac on?
Old Aug 17, 2011 | 01:58 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: A/C help
no thats the dryer, the clutch is the inside part of the pulley on the compressor i believe
Old Aug 17, 2011 | 01:59 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: A/C help
Oh ok, thanks, I'll check that out and let you guys know what happens after work tonight
Old Aug 17, 2011 | 06:56 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: A/C help
The clutch did engage, and the air was pretty cool, I also havent used it for the last tow weeks and it wasn't that hot out either
Old Aug 17, 2011 | 09:16 PM
brandon lee's Avatar
Car: 87 IRoc Z
Engine: 350 tune port L9
Re: A/C help
I have a 87 IROC that i just bought and the ac is blowing out of the defrost mostly very little out of the vents but under hood where the ac and heater box is it feels like air is coming out and you can feel air where the vent where the windshield wiper is on the passenger side could that be why its doing that
Old Aug 17, 2011 | 10:26 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
Re: A/C help
is your vacuum line that goes to the dash to change the controls connected?
That will default to defrost upon failure. Worth checking.
OP...Check the freon level for poor cooling issues. You need to know the high and low values. Only proper gauges should be used and not those walmart/part store top up gimmicks. Too high a pressure is bad and likely means air in the system. If you can't do that try to find a shop fairly priced for diagnostics.
Good luck.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
