Broke rod? Piston? Valves? Help!!!!!
Car: 1989 Trans Am GTA
Engine: 350 Tpi rebuilt
Ok soooooo built 350 cam, heads headers, and we found an intake gasket leak it was burning coolant so we pulled the spark plugs and found this,
Wtf
seriously how would that happen? The only thing I could think of would be broken rod made the piston slap the plug or broke piston any ideas?
Wtf
seriously how would that happen? The only thing I could think of would be broken rod made the piston slap the plug or broke piston any ideas? Joined: Oct 2001
Engine: 4++,350 & 305 CIs
Re: Broke rod? Piston? Valves? Help!!!!!
That is what the spark plug guilds call mechanical damage..
Time to pull the head and take a better look.. Pulled many plugs out like that and never had good news..
Good luck!
Good luck!
Ahhhh I don't wanna pull the head, the motor was in my 72suburban and I pulled it to put in my brothers trans am but he has had nothing but issues collapsed lifters the valves were slapping hard it's just one more thing, if it's a rod or piston I'm seriously just gonna pull the motor and completely rebuild it
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Could also be something foreign in the cylinder that did it. Either way it still warrents taking off the head to see whats going on. If it puked a rod, you may not have much to work with rebuild wise.
Car: 88 Camaro SC
Engine: SFI'd 350
If it had serious valvetrain issues, it could also be a broken valve. That would cause the coolant consumption issue as well as the detached valve head would likey crack the head and cause it to leak coolant. Either way it would result in serious engine damage.
Ya I'm gonna try and get the head pulled after work today and I will post photos/update. Thanks for the info update tonight!
Definitely foreign matter in that cyl. If not a broken part WITHIN the cyl, then it was some kind of debris that fell down through the carb.
Gonna need to pull the head and make sure nothing else is tore up. No real way around that.
So just incase anyone was still wondering I got the head off and the piston was split in half and turned sideways, how that happen I have no idea, I'm gonna take a picture when I get home tonight but I will have to upload it when I get to work tomorrow. So now we have the motor apart and are figuring out what pistons to buy
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Wow... ouch... so other than coolatn consumption it was actually running okay?
Ya that's what was so weird, it would fire up and run but had a slight noose and was leaking, so I think the rod and the pieces of the piston were still all together till we pulled the head
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
