What is this thing leaking all my oil!? HELP
Old Aug 28, 2011 | 03:26 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
So yesterday i checked my oil and my oil marked empty.. i thought it was my valve covers but upon closer inspection today i found this thing on the back of my intake which im assuming is an oil pressure switch/sending unit although im not 100%.
I turned on the car and immediately the switch started dripping oil constantly from the little black fitting.
Heres a picture of what im talking about, what can i do to stop the leaking? Should i remove the switch completely? it doesnt seem to be connected and my oil pressure gauge doesnt work, so i dont know if theres some sort of correlation but there doesn't seem to be a plug anywhere near the switch. Is it common for these things to leak? Im not too familiar with this car yet since i bought it a couple of days ago. Any help appreciated.
Old Aug 28, 2011 | 03:46 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: What is this thing leaking all my oil!? HELP
I would just replace it. They are not expensive.
Old Aug 28, 2011 | 03:49 PM
mark wells's Avatar
Car: 85 Trans Am
Engine: 383 ci
Axle/Gears: posi 342
That is the oil sending unit, and yes it needs to be replaced. There should be an orange and a brown wire that attach to a single plug that would go to the end of the sending unit. Probably fell behind back of the block or could be back behind the drivers side head.
Old Aug 28, 2011 | 03:53 PM
Car: 1986 Iroc-Z
Engine: 355
Thanks for the confirmation guys im gonna head down to my local autoparts and buy one i called and they said it was 9.99 ill see if i can find the orange and brown wire.
Im just glad it wasnt my intake gasket, and i was beginning to think i had valve covers from hell...
Old Aug 28, 2011 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Hope you took it off and took it with you to parts store - there's a dozen diferent "oil pressure" gadgets available for these cars, and odds are the counter-person will hand you the wrong one.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
Bob88GTA
Aug 18, 2015 03:31 PM
MY87LT
Aug 17, 2015 08:43 AM
86White_T/A305
Aug 17, 2015 12:16 AM
