My 083's are back! PICS!
Old Aug 29, 2011 | 10:21 AM
Eagle223usa's Avatar
Car: 89 5.7 IROC/95 LT1 Corvette
Engine: All 5.7's
Transmission: 700R4 (Roessler)/ZF6
Axle/Gears: 10 bolt Zexel 3.23's. CTW 17" wheel
After much trial and tribulation my heads are back and on! I ported them my self, I had a 3 angle valve job done with a 30 degree back cut. I went with LT4 springs and Viton positive seals. Also had a clean up done on the head surface of 10 thous.
Attached Thumbnails My 083's are back! PICS!-0826111700.jpg   My 083's are back! PICS!-0826111830.jpg
Old Aug 29, 2011 | 12:21 PM
Guest
Guest
Posts: n/a
Re: My 083's are back! PICS!
What, no 75 degree bowl hog?
Old Aug 29, 2011 | 01:56 PM
Engine: All 5.7's
Dude, I know your joking. Kevin did hit the bowl with the Serdi just to clean them up. I opened the bowls to 85%, according to the information I had on hand this is correct for a street car.
Old Aug 29, 2011 | 02:21 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
pics of port work?
Old Aug 29, 2011 | 08:12 PM
Engine: All 5.7's
I'll find some......
Old Aug 29, 2011 | 09:03 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Im about to buy some 083's. What do you mean by "no 75 degree bowl". Im gonna get mine P & P.
Old Aug 29, 2011 | 09:17 PM
Eagle223usa, do your GM 1.6 RR fit inside your center bolt valve covers? I have a set of Summit G6906 and mine look so similar to your GM RR. My point is mine dont fit in my center bolt valve cover.
here are what mine look like...
Old Aug 30, 2011 | 02:11 PM
Engine: All 5.7's
I believe the GMPP's were made by Crane for GM. And yes they fit with centerbolts!
Old Aug 30, 2011 | 02:34 PM
Really. What was the part number for your RR's? Im trying to sell my RR's but so far im unsuccessfull.
Old Aug 31, 2011 | 12:15 AM
Engine: All 5.7's
Porting pics... First, Just back from the machine shop. Next two are as porting progressed. Sorry they are out of sequence, I just noticed I had the first pic mislabeled, fixed now!
Attached Thumbnails My 083's are back! PICS!-0819110118.jpg   My 083's are back! PICS!-0310112114.jpg   My 083's are back! PICS!-1107101344.jpg
Old Aug 31, 2011 | 12:18 AM
Engine: All 5.7's
Close up of exhaust port...
Old Aug 31, 2011 | 12:25 AM
Engine: All 5.7's
Sorry Bro, I don't have the part numbers. These were included with the car. They just have a bowtie and 1.6 stamped on them.
Old Aug 31, 2011 | 12:36 AM
Dang. Its all good bro. Thanks for replying though. Good luck with your heads man. So far they look good.
Old Aug 31, 2011 | 12:55 AM
Engine: All 5.7's
Thanks, I want to hear them RUN! Other parts are still waiting to get ceramic coated....
Old Aug 31, 2011 | 08:27 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If those are the same rocker you have thats in the pic you dont have the correct rockers for centerbolt valvecovers.
Crane used to make the rockers 4 GM, I think scorpion does now
Old Aug 31, 2011 | 08:32 AM
You are very correct. These RR that I got are too wide for my centerbolt covers. My friend has the blue self aligning Scorpions and they do fit under his centerbolt covers. So not to hi-jack the thread, let's get back to the 083 topic shall we?
Old Aug 31, 2011 | 09:15 PM
Damon's Avatar
From the GMPP 2008 catalog the aluminum full roller rocker arms (blue in color, self-aligning style, rocker ratio and bowtie emblem samped on the top) are available in two ratios:
1.5:1 ratio, part number 12370838 for a full set (12367345 for a single rocker arm)
1.6:1 ratio, part number 12370839 for a full set (12367346 for a single rocker arm)
Old Aug 31, 2011 | 09:49 PM
Right on man. Thanks for the heads up.
Old Sep 5, 2011 | 11:18 AM
Engine: All 5.7's
Got some pics of the rockers....
Attached Thumbnails My 083's are back! PICS!-0901111131.jpg   My 083's are back! PICS!-0829111154.jpg
Old Sep 5, 2011 | 11:20 AM
Engine: All 5.7's
Oh, I also used GMPP .028 gaskets to maintain compression.
Old Sep 5, 2011 | 12:39 PM
AHH. Im gonna look into a set of those RR. Thanks for the picture man.
Old Sep 5, 2011 | 04:27 PM
Engine: All 5.7's
Anytime Brother!
1985chevydude
Aug 20, 2015 12:29 AM
tecustomz
Aug 16, 2015 02:28 PM
cstrobel65
Aug 15, 2015 10:19 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
