Low oil pressure? sometimes?
Old Sep 1, 2011 | 01:54 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
Ok so i was looking at my oil pressure and at idle its at 0, then when i press the gas it gets up to like 20. Sometimes its at 30 and stays there with gas pressed and at idle. whats wrong Thanks
Old Sep 1, 2011 | 04:41 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Low oil pressure? sometimes?
It could be a bad gauge sender, bad dash gauge, or stuck pressure relief in the oil pump. Its time to hook up a mechanical oil pressure gauge and verify if the oil pressure is really getting that low.
Old Sep 1, 2011 | 05:02 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
more likely than not your problem is the oil press. sensor . it's located just above the oil filter , easy to change . be careful of brittle plastic on the elect. connector . good luck .
Old Sep 1, 2011 | 05:08 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
i changed the sender is that the same as the sensor?
Old Sep 3, 2011 | 10:11 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Senders are for gauges, sensors are for computers.
Old Sep 3, 2011 | 04:10 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
is this the one? http://cgi.ebay.com/ebaymotors/Oil-P...item2566b82059
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
