stock 305 tpi. performance ideas??
Old Sep 6, 2011 | 01:20 PM
dfrontman's Avatar
I just recently bought a 1988 iroc-z 5 speed with a stock 305 tpi in it. I have a decent amount of money for performance upgrades. I was just wondering what I should do. I already added a new exhaust, and headers. I don't want to do an engine swap. Any ideas would be greatly appreciated.
Would putting new heads, cam, throttle body, and a higher flow intake base and runner really be worth the money? to actually see a big gain in performance
Old Sep 6, 2011 | 08:51 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: stock 305 tpi. performance ideas??
the biggest performance gain for the least money would be a 350. but since you dont want to do an engine swap, everything you mentioned will help out. but after all is said and done youll still be in mild 350 performance numbers. nothing very impressive. itll be fun to drive on the street, but not the animal it could be with a built 350 under the hood.
Old Sep 6, 2011 | 11:15 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Welcome to T.G.O.!
The search box above will help you with most of your questions. You could even simply type in 305 and see what comes up. Based on what you are asking, I would start reading this read:
https://www.thirdgen.org/forums/tpi/...azy-305-a.html
Old Sep 7, 2011 | 03:34 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
When I had my 305, I had a full exhaust headers to tips, a cam, and a TPIS intake and runners and it ran pretty good.
Old Sep 7, 2011 | 10:36 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
port the heads, and get new valves. clean everything up and replace the head gaskets.
it will run like a new car
Old Sep 8, 2011 | 01:04 AM
piratagt's Avatar
Car: 1991 Chevrolet Camaro
Engine: 5.7l TPI
Transmission: 700
i have 1991 305 TPI with ported heads intake side, 1.94 intake valves(from 350 TPI heads), port match heads and intake
ported plenum, shorty 1 5/8 headers , 2 1/2 inch exhaust pipe with Y pipe
and run pretty decent
Old Sep 9, 2011 | 06:07 PM
dfrontman's Avatar
thanks for the responses. Im gonna try a few of the suggestions, and see how it goes.
BlueIroc-Z
Jun 9, 2019 03:22 AM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
