88 Formula(will turn over but doesnt start)
Old Sep 18, 2011 | 10:00 PM
formulaboy757's Avatar
Car: 1988 pontiac firebird formula
Transmission: 5 speed manual
I just got my 88 Formula. It's got the 305, manual trans. I put a new starter on it and a new fuel filter. It has been sitting for about 10 years. It turns over fine but wont start. Does anyone have any clue where to start?? I have tested all the fuses and they are all getting power. i have to pull the engine to replace the freeze plugs and make sure the block isnt damaged. I'd like to get it running b4 i drop but so much into rebuilding the engine.
thanks,
Lee
Old Sep 18, 2011 | 10:31 PM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Re: 88 Formula(will turn over but doesnt start)
can you hear the fuel pump running ????
Old Sep 18, 2011 | 10:34 PM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
push on the valve on the fuel rail port to check for fuel and pressure.. next check for spark @ a plug if no check the coil for spark if no... control module is next... possible pickup coil.... sounds like bad fuel
Old Sep 18, 2011 | 11:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine only needs two things; fuel and spark.
You are missing at least one of them
Old Sep 19, 2011 | 08:32 AM
We'll i unhooked the fuel filter and it was getting fuel through it fine. Im pretty new to this so does anyone have a good site that i can print out what to do?? and where it all is??
Old Sep 19, 2011 | 02:10 PM
torque_is_good's Avatar
it's been sitting for 10 years!!!!!
stop
drain the tank, clean it, clean out your fuel lines, install a new filter and call it done
Derick15
Sep 17, 2016 05:28 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
ZsTransAm
Aug 11, 2015 07:30 PM
