TBI Open Element Air Cleaner
Old Sep 25, 2011 | 04:37 PM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
Hey guys, I've been wondering if anyone knows which open element air cleaner will fit my car. I have a 305 TBI. My only concern is whether or not the drop base units will mess with my throttle linkage or if the flat base one's will clear the hood. Can anyone give me some guidance in this area? Thanks in advance.
Old Sep 25, 2011 | 05:41 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: TBI Open Element Air Cleaner
https://www.thirdgen.org/forums/tbi/...ment-base.html
If you hit the search button, there should be around a thousand more treads covering this detail
Old Sep 25, 2011 | 10:41 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
You will have no problems with an edelbrock drop base, but with a flat base you'll need a stud extender to make it fit
Old Sep 26, 2011 | 07:03 AM
thomas1976's Avatar
Car: 91 Trans am
I have used the summitracing flat base cleaner assembly with the stock stud. Maybe your stud was not stock?
Old Sep 26, 2011 | 08:49 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
I guess not, or maybe different tops on the cleaners
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
