starting issue... won't
Old Oct 10, 2011 | 11:08 AM
LIDNR2's Avatar
Car: '89 Formula 350, T-Top
Axle/Gears: Stock 3.73's
need help/ideas...
my 89 formula350 sits in a barn for long periods of time. now when i started useing it more she starts no problem, wait for idle kick down, drive away. but now she won't restart, like thers no fuel, but i hear the fuel pump primeing. today i started it, let it run till operating temp, shut down, let sit for 15/20 minutes, will not restart. any ideas? car has 23,000 orig mi. totally still stock,except for K&N air filter.
Old Oct 11, 2011 | 10:02 AM
LIDNR2's Avatar
Re: starting issue... won't
emptying gas tank. Going to try new fuel filter. fresh gas. I've had "hot start" issues before, this isn't it. this problem acts like no fuel.
Old Oct 12, 2011 | 03:32 PM
RAS's Avatar
RAS
Next time it won't start check for fuel pressure and spark, that will narrow it down...
Old Oct 13, 2011 | 10:19 AM
LIDNR2's Avatar
I got lazy. drove to dealer, left it running, idle not steady, bouncing between 500/800.
drove it into work bay, mechanic turned car off, and ... won't restart. checked fuel injector wiring, then starter quit. Bad ECM? they gave me ride home. Dealer, first mistake. expensive, but hopeful...
Old Oct 13, 2011 | 10:24 AM
royrabb's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0 TBI
Transmission: 700-R4
Axle/Gears: 2.73 ugh..
I had this problem one time and it ended up being VATS, as bad as I hate to open that can of worms. On other vehicles that I've had though, similar but not exact problem, it turned out being the alternator going out.
Old Oct 13, 2011 | 10:30 AM
BillyTheGoat's Avatar
Car: 1989 Trans am
check for spark when it won't start. Could be ignition module or pickup coil
Old Oct 13, 2011 | 10:43 AM
LIDNR2's Avatar
Thanks, I just called dealer. had service manager tell mechanic, make sure i have spark, and pressure before ECM is bought. so now I wait...
Old Oct 13, 2011 | 10:35 PM
curtalert89's Avatar
Car: 91 Camaro R/S
Engine: Tbi 350
Transmission: auto4
Axle/Gears: Stock
Tonight after driving my 88 camaro v6. It decided not to start. It has gas. But it sounds like its not getting it now. This its th he first time this has happened. Any suggestions what out could be?
Old Oct 21, 2011 | 01:47 PM
LIDNR2's Avatar
Hurray! Just got my baby back from the dealer. Expensive, but runs like it did. New Ecm, new fuel injectors, new starter. 1600.00$, ouch. But still smiling. Thanks for all your help...
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
