thinking of buy a camaro 1985. but not sure
Old Oct 18, 2011 | 06:06 PM
evoallover's Avatar
Hi all. i know nothing about camaro, the car i went to look at has got a low compression fault and I'm not sure how you would fix it. maybe piston ring need to be changed ? don't know if this helps its a 5.7 V8
Old Oct 18, 2011 | 06:17 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Re: thinking of buy a camaro 1985. but not sure
Well how much is the seller asking for, and what kind of condition is it in?
Old Oct 18, 2011 | 06:49 PM
evoallover's Avatar
well it's in ok condition. paint is a little flat. its got edelbrock carb, tubuler headers, B+M shifter, TH400 gearbox,11 mot no tax. and he said i can have it for £1600. he said is got a little blue smoke on start up and he had it tested and it has low compression.
he said this was the test results. should be 175 down to 125. and all the others as down to 150. but i have no idea what that means lol.
Old Oct 19, 2011 | 05:49 AM
evoallover's Avatar
So help would be nice. Should I should I not ?
Old Oct 19, 2011 | 06:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO, super.
Just an FYI (though you may already be aware): an 85 wouldn't have a 350 unless it's been swapped in.
Good luck.
JamesC
Old Oct 19, 2011 | 06:37 AM
evoallover's Avatar
Yer it was swapp
Old Oct 19, 2011 | 07:37 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
I'm guessing fried pistons rings or bad head gaskets (or valve seals?). But then again, I'm not exactly an expert just yet so wait for someone else to verify my analysis.
I'd see if I could score it for a few hundred pounds less (Guys, the asking price is about $2500 USD), but if you're not ready to get into the engine and work on it, don't get it.
Old Oct 19, 2011 | 07:43 AM
evoallover's Avatar
I'm up for the work just don't no any thing about them.
Old Oct 19, 2011 | 10:08 AM
evoallover's Avatar
I think I might just put it back to stock
Old Oct 19, 2011 | 10:13 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Why would you get rid of a perfectly good 350 (albeit needing some work) for a 305?? Everything that's stock flows like crap, so you'd be better off keeping it as it is and finding out what the problem is.
Do A LOT more research on here and elsewhere. Also, subscribe to at least 2 hot-rodding magazines, one of which is Chevy-oriented
Old Oct 19, 2011 | 10:27 AM
Aaron_SK's Avatar
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
I don't know if automotive prices over there are inflated, but that's about twice what you would pay in this country.
If you are truly interested in this car take it to a mechanic and have it checked out properly, including a good compression test. You are not looking for specific compression numbers so much as you are looking for lack of variation. They also need to check it wet and dry to rule out bad rings.
Why? Magazines sold in this country are nothing more than advertising flyers for companies selling bolt-on Chinese chrome junk.
Old Oct 19, 2011 | 10:39 AM
evoallover's Avatar
There you go, that's what I wanted to know if it was worth it, and now I no it is
Old Oct 19, 2011 | 11:31 AM
evoallover's Avatar
well prices in the uk are high. but my friend is a mechanic so i think i should be ok
midge54
Jan 29, 2017 07:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Dquickshift
Aug 12, 2015 06:21 PM
