Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Old Feb 10, 2019 | 10:14 AM
  #251
byenzer's Avatar
Re: Vacuum Lines Diagrams!!! I GOT THEM ALL!!!!!
Originally Posted by oneoldman
None of the diagrams I've seen answer my question. I have an 87 Camaro 2.8L mpfi the double vacuum port on rear of upper plenum I know the large side goes to the brake booster I have a hose from the vacuum cannister in left front fender and a small very short plastic line from firewall at the a/c heaterbox area. I need to know what type of connector marries the saller port on the plenum to these other two lines that I think are for the heater controls. The car was disassembled when I bought it.
HELLO:
If you found the diagram for your 1987 2.8L, with the vacuum can in the front left fender, may I have a copy? Thank you. Brett
Old Feb 11, 2019 | 08:02 AM
  #252
byenzer's Avatar
THANK YOU!
Might you also have the vacuum diagram for the HVAC vacuum hoses for a 1987, 2.8L, MPFI? My Camaro has the vacuum accumulator ball under left front fender. The P.O. removed the vacuum hoses for the accumulator ball, the heater valve, and the thru firewall hoses too.
Again, thank you,
Brett
Old Feb 11, 2019 | 08:45 AM
  #253
All of that is not part of the vac diag unfortunately. The diag covers the "engine" only, but the accumulator and all that, is part of the "car" and varies according to what options are installed.
However, it's pretty simple, and doesn't depend on what year (up to a point) the car is or what engine it has. There will be a line coming off of a vac source on the plenum or intake manifold; it will go to a check valve, pointed in the direction that allows vac to suck through it, but would prevent "blowing" in the direction of from the vac source toward the rest of the world; there will be a T fitting (some check valves incorporate the T); one leg of the T goes toward the HVAC control head (the purple small plastic vac line through the firewall) and the cruise, the other goes toward the Orb Of Power in the fender. The purpose of it all is to allow vac through the check valve when the vac is hogh (idle & cruise), then when the engine vac falls (hard acceleration), the Orb holds enough vac to keep the little doors under the dash that direct air from relaxing, and the check valve prevents the stored vac from simply being drained off into the engine. The white little plastic line through the firewall goes to the heater control valve, if your car has that.
Old Feb 14, 2019 | 10:41 PM
  #254
TaCowboy's Avatar
I have an 88 Trans AM GTA 5.0L Tune Port Inj, I am replacing all the vacuum lines and one is just laying by the batter. I need a diagram . If any of y'all could help Id be very grateful
Old Feb 14, 2019 | 11:40 PM
  #255
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Post #239 should sort you out
Old Aug 13, 2019 | 03:52 PM
  #256
chris004's Avatar
Car: 1991 Camaro RS
Engine: 305 T.B.I.
thanks for the diagrams!
Last edited by chris004; Aug 14, 2019 at 08:20 AM. Reason: answered my own question
Old Aug 13, 2019 | 04:06 PM
  #257
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Post 15
Originally Posted by Chevy86 IROC-Z
not sure which one you need but here is manual and auto (tranny).
Attachment 381920
Old Aug 13, 2019 | 07:49 PM
  #258
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Gonna have to look at my own post. Lol. I'm in need of the 2.8 V6 vac line diagram.
Old Aug 15, 2019 | 12:02 AM
  #259
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Maybe a stupid question, but does the 3.8L turbo from 89 not have any vacuum lines?
Old Aug 21, 2019 | 05:16 PM
  #260
DBuck's Avatar
Car: 1982 TA Recaro
Transmission: 4 speed
Axle/Gears: ?
I have a 1982 Trans Am Recaro that I have owned since new. It has a Standard shift 4 speed and carburetor. Do you have a vacuum line diagram for it. I have only found the one you posted for the automatic with carburetor. Thanks, Dan
Old Aug 22, 2019 | 09:43 AM
  #261
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Well, I guess I'll add the 3.8L turbo vacuum diagram so the OP is not lying.
Old Mar 26, 2020 | 03:30 PM
  #262
Stew6343's Avatar
Do you have one for a 69 Pontiac Firebird with the 350 HO and a 4 barrel quadrajet by chance?
Old Mar 26, 2020 | 04:19 PM
  #263
Stew6343's Avatar
can i get the vacuum diagram for a 69 Pontiac Firebird with the 350 HO and a 4 barrel quadrajet?
Old Mar 26, 2020 | 04:38 PM
  #264
Stew6343's Avatar
69 pontiac firebird with a 350HO and a 4 barrel quadrajet
Old Mar 26, 2020 | 04:41 PM
  #265
OrangeBird's Avatar
Car: 1989 Firebird
Most likely not , this forum is exclusively for the 1982 through 1992 F bodies (The third generation of the Camaro/Firebird , hence the name "Third Gen . Org") , your best bet will be with a first gen F body forum . It's not like the info is here and no one is giving it to you , It's just that most of us only have info stored for the third gen cars .
Old Apr 23, 2020 | 03:11 AM
  #266
Morteza Rahnama's Avatar
HI
1986-1989 2.8L FUEL INJECTED
PLZ,
TNX
Old Apr 23, 2020 | 10:27 AM
  #267
Engine: Lb9
Transmission: M20
You need to look post 26
Old May 26, 2020 | 09:40 AM
  #268
Firebabe's Avatar
Car: 89 Firebird Formula
Engine: 5.7
Thanks!
Old Jun 25, 2020 | 06:24 AM
  #269
Markus Mac's Avatar
Originally Posted by Garges24
86 Z28 carb 305 vin h
O have an 84 305 auto trans am whixh6 someone started egr delete and desperately trying get it to run it has Eldebrock 600cfm 4 barrell now and egr caped off i have no idea were vacum lines go whats should or shouldn't be their any help be appreciated
Old Jun 25, 2020 | 07:14 AM
  #270
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Request for:
1990-1992 3.1L FUEL INJECTED
Thanks!
Old Jun 25, 2020 | 07:32 AM
  #271
Monteman71's Avatar
Car: 1986 Iroc Z28
Engine: 305 LG4
Hi
If you have the vacuum diagram for a 1986 305 carbed Canadian car,I would appreciate.
If I missed it here already,apologies
Shawn
Old Jul 21, 2020 | 09:17 PM
  #272
ozzie280's Avatar
Car: 1992 camaro z28 5.0
Transmission: auto
Hello, 1992 5.0, TPI, auto trans. please send to ozziesalazar.jr@gmail.com
thanks,
Old Aug 7, 2020 | 02:06 PM
  #273
Raoul Garza's Avatar
I just collected ALL vacuum lines from 82 - 92 TG F-Bodies!!!! If anyone needs one, search below on this 1st page. Models covered with vacuum lines are:
1982-1984 2.5L TBI
1985-1986 2.5L TBI
1982 2.8L CARBURETED
1983 2.8L CARBURETED
1984 2.8L CARBURETED; EXCEPT CANADA
1984 2.8L CARBURETED; CANADA
1985 2.8L FUEL INJECTED
1982 5.0L CARBURETED
1983 5.0L CARBURETED
1984 5.0L CARBURETED; EXCEPT CANADA
1984 5.0L CARBURETED; CANADA
1985 5.0L CARBURETED; EXCEPT CANADA
1985 5.0L CARBURETED; CANADA
1986 5.0L CARBURETED; EXCEPT CANADA
1986 5.0L CARBURETED; CANADA
1987-1988 5.0L CARBURETED
5.0L CROSS-FIRE FUEL INJECTION
1988-1992 5.0L THROTTLE BODY INJECTION; MANUAL TRANSMISSION
1988-1992 5.0L THROTTLE BODY INJECTION; AUTO TRANS.
1985-1986 5.0L TUNED PORT INJECTION
1987-1989 5.0L AND 5.7L TUNED PORT INJECTION
1990-1992 5.0L AND 5.7L TUNED PORT INJECTION
I am having a very difficult time with my 1989 5.0 Camaro with tbi. Broken vacuum lines everywhere, open vacuum ports, no T connections. Having a particular issue trying to find out where this vacuum port should be connected to
Old Nov 25, 2020 | 11:52 AM
  #274
Westin Jindra's Avatar
Car: 1986 T-top IROC camaro
Engine: 6.2L LT1 V8
Transmission: 4L 80E
Axle/Gears: 10 bolt LG4 3:73 gears
1984 v6 2.8L Camaro if u have some time please
Old Nov 25, 2020 | 12:18 PM
  #275
Should be on page 1.
Old Nov 25, 2020 | 01:46 PM
  #276
Raoul,
That hose is part of the "car", as opposed to the "engine"; therefore is not part of the "engine" vac diagrams.
It serves the HVAC and cruise control (if equipped).
Old Mar 14, 2021 | 12:37 PM
  #277
9125aniv's Avatar
1982-1984 2.5L TBI
1985-1986 2.5L TBI
Need 91 3.1v6 vac diag please
Old Mar 14, 2021 | 01:13 PM
  #278
Engine: Lb9
Transmission: M20
You just need to look ! Post 29
Old May 29, 2021 | 10:44 PM
  #279
myers's Avatar
Car: 86 Trans am
Hi i was trying to see if yall could help me out I'm doing the TPI to carb swap and needed help with vacumm lines and the pcv valve. Since I no longer have the charcoal cansiter, egr, smog, or any of that stuff a bunch of lines are no longer there and I was trying to see what I needed to hook up for it to work. Much apperciated!
Old Dec 15, 2021 | 06:57 PM
  #280
Buckey's Avatar
Want a title? Post!
Hello could I get some for my 1991 5.0l TPI. Thanks
alexwitbeck@protonmail.com
Old Feb 16, 2022 | 10:37 AM
  #281
aeer's Avatar
2015 Cazador czd180y12-2 vacuum line diagram please
Old Mar 30, 2022 | 06:31 AM
  #282
bernmntsa's Avatar
Can anyone help, I need a vacuum line diagram,
Where can I get a diagram for hooking up the vacuum hoses for a 1985 GMC S15 with a 2.8 L. automatic. It has a V6 4x4.
Also does anyone know where the line goes from the manifold outlet right behind the Carburator
Old Mar 30, 2022 | 08:20 AM
  #283
Might want to check a S truck forum.
This one is devoted exclusively to 82-92 Firebird & Camaro.
Old Apr 18, 2022 | 07:13 AM
  #284
bernmntsa's Avatar
I need a vacuum diagram for a 1985 carburerated, 4x4. I need to know where the vacuum line for the HVAC system is tie in. Would really like to delet as much as possible. Any help will be appreciated
Old Apr 18, 2022 | 10:53 AM
  #285
Engine: Lb9
Transmission: M20
Read post above yours
Old Apr 18, 2022 | 01:38 PM
  #286
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
To paraphrase a somewhat-famous fictional prison warden, what we have here is a failure to communicate.
When OP stated that he has "ALL vacuum lines from 82 - 92 TG F-Bodies!!!!," that's what he meant----only Camaros and Firebirds build between the years 1982 to 1992. No 4x4s, Toyotees, Hondoos, mid-sized pickup trucks, Mopars, 2015 Cazadors (WTH is a Cazador???), Fjords, skateboards, buckboards, or floorboards.
So, for all you non-3rd-gen vehicle owners searching for vacuum line diagrams, The Google may be able to direct you to a more-appropriate interwebz forum.
Good luck and take care.
Old May 11, 2022 | 03:35 PM
  #287
Alan Darr's Avatar
I have a 1989 Pontiac Trans Am Turbo 3.8L pace car.
looking for the vacuum diagrams for this unit--
any idea where I can find them??
thanks
alan Darr, lakeland florida
Old May 11, 2022 | 03:36 PM
  #288
Alan Darr's Avatar
needing vacuum diagrams 1989 Trans Am turbo 3.8L
needing the vacuum diagrams for the engine and turbo. any ideas appreciated.
thanks in advance (TIA)
Alan
Old Jul 15, 2022 | 07:35 PM
  #289
Dual86TA's Avatar
Car: A pair of 86 Trans Am WS6's
Engine: 305/350/383
Transmission: 700r4/Borg Warner t5 /tremec t56
I'm in need of the vacuum line diagram for the digital HVAC climate control for an 88 GTA doing a conversion and I'm going about it a little bit differently and so far so good I just have come across a few images where it showed an extra vacuum line coming through the firewall and I just wanted to make sure I had the right count and positioning
Old Jul 18, 2022 | 05:57 PM
  #290
Dual86TA's Avatar
Engine: 305/350/383
1982-1984 2.5L TBI
1985-1986 2.5L TBI
​​​​​​​ can I get vacuum line diagrams for 87-89 tuned port in particular I'm looking for the digital climate control vacuum line diagrams not so much for under the dash but for where they go through the firewall into the engine bay. Thank you in advance
Old Jul 19, 2022 | 09:54 AM
  #291
if your car has the heater diverter valve, then there are 2 vacuum lines that com out of the wiring harness/loom just behind the distributor.
Old Jul 19, 2022 | 10:08 AM
  #292
Dual86TA's Avatar
Engine: 305/350/383
okay that's kind of what I was figuring and that pretty much confirms it for me I thank you for that, I guess the next question I would have is if I wasn't going to install a heater diverter valve and was just going to utilize the vacuum Supply from the engine to the HVAC system which of the two taps on the plug would I want to use the one that goes to the purple line or the one there goes to the gray? See I would think most of the stuff should be obvious just looking at it but I thought that in the past and they've been proven severely wrong and mistakes were made. Thanks again in advance
Old Aug 12, 2022 | 08:58 PM
  #293
b loop1000's Avatar
Hoping you just might have one for a '77 El Camino 350 4bbl in California
Old Aug 12, 2022 | 09:37 PM
  #294
Engine: Lb9
Transmission: M20
Lmfao what type of site do you think this is
Old Aug 13, 2022 | 06:13 AM
  #295
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
https://googlethatforyou.com?q=Vacuu...n%20California
Old Feb 18, 2023 | 09:51 AM
  #296
jacktripper219's Avatar
PLEASE I CANT FIND A VACUUM HOSE DIAGRAM FOR A 2007 Mercedes Benz S550 5.5l V8 (w221)???
Old Feb 18, 2023 | 09:56 AM
  #297
Engine: Lb9
Transmission: M20
look on the hood sticker, wouldn’t make much sense it would be on a thirdgen f body
platform page would it 😂
Old Jul 25, 2023 | 11:13 AM
  #298
Huddyb’sLT's Avatar
I need the diagram for a 1987 5.0 305 carbureted please/thank you
Old Jul 25, 2023 | 11:17 AM
  #299
Engine: Lb9
Transmission: M20
did you look at post 28 ?
Attachment 381821
Old Jul 25, 2023 | 04:45 PM
  #300
3rd gen f-bodies only board. Sorry.
