help me ID this block.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: help me ID this block.
https://www.thirdgen.org/forums/tech...010-block.html
The suffix code stamped on front of block will tell you what it was
when it left the factory
Car: 1991 Formula
Engine: 350TBI
That's the problem, there is no vin in that location
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's ok, the VIN doesn't tell you anything useful.
3941174 has a 3.25" stroke, 3970010 has a 4" bore, so it's a 327.
Car: 82 Z28
Transmission: T400
Car: 82 Z28
Transmission: T400
A BLOCK is not an ENGINE so it doesn't have a CID "size". It's a 4" bore block.
It was used in the 302, 327, and 350, but not the 307 which has a different bore.
It's not a "350" or whatever until it gets a crank installed into it. Meantime, it's just a block.
Doesn't matter which of its possible sizes it started out life as, unless you're building a "numbers matching" type of restoration. None of that left any trace in it. Iron has no memory. Attempting to determine what it "was" when it was new is a futile non-productive waste of mental energy which only serves to demonstrate to people who know what they're doing, that you're a n00b, and makes them laugh at you behind your back. Your energy should instead be devoted to working on what it WILL BE next.
The crank that's in it is a low-perf cast crank for a 327, so that's what it IS now, regardless of whatever it STARTED OUT as. Perfect thing to throw in the trash and get a 383 crank instead. If the block is even any good: check how far it's been bored before making any plans for it.
Engine: 383 Carb
Transmission: 4L60
Engine: 383 Carb
Transmission: 4L60
Car: 1991 Formula
Engine: 350TBI
It won't need another rebuild untill 10ish years from now and I'm sure my car will be scrap by then anyway lol
It's just .060 over
Probably why it has that crap crank in it.
If the cyl walls aren't PERFECT and you're looking to build a motor, might as well start looking for another one right away; because that one is done.
Car: 1991 Formula
Engine: 350TBI
Car: `86 SS / `87 SS
'86-up one piece seal engines leak less.
'87-up allow use of OEM style roller cam lifters (less $ than aftermarket lifters)
Anything those years and newer will be less prone to bore wear than that old worn out block, even when it was new.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
looks like your generic 70's 010 block (any 4 inch bore CID engine) extremely common. Rebuildable 350 blocks are a dime a dozen, if it needs any machine work I'd look for a 1 piece rms block with factory roller pervisions
Bottom line: It's nothing special in any manner way shape or form, rather it's about the most commonplace run-of-the-mill block you'll ever run into, with a crappy crank stuck in it. If it works, run it and enjoy it (or not); if it needs work, it's not rebuildable, and it's time to find another, which might as well be a late-model w roller provisions.
o
