oil pressure DROPS during take off....
Old Oct 31, 2011 | 03:42 PM
alexquade's Avatar
Car: 1992 RS
92 camaro rs. 305 tbi. okay, just noticed this today. but when i take off, my oil pressure will drop almost to red before actually going to normal. and right before i parked my car earlier. i pulled into the drive and looked and it was at 0. then, my brother went drive it, and it went normal, except during take offs. normal idle, it'll be right below 30. taking off, almost red lines to 0, and then goes to the middle line after 30. until i stop. any idea???? bad sending unit? bad gauge? bad oil pump? idk. but, i have been having some problems with my gauges. but mainly my speedometer... and recently my gas gauge dropped ALL THE WAY past full and hit the dash bezel. then went to full a lil while later.... i think the cars just possessed.....
Old Oct 31, 2011 | 05:13 PM
grumpyvette's Avatar
Re: oil pressure DROPS during take off....
have you verified oil level on the dip stick, it sounds like your about 2 quarts low
Old Oct 31, 2011 | 06:05 PM
alexquade's Avatar
Car: 1992 RS
this is the first time it has ever happened. i do have an oil leak, but its my valve stem seals. but normally when its low like this, it won't smoke at start and it still is. ive been driving it, so ima hafta check it in the morning. thanks!!!
Old Oct 31, 2011 | 10:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is the pickup still on the pump?
Old Oct 31, 2011 | 11:01 PM
alexquade's Avatar
Car: 1992 RS
i'm sorry... my what??? haha. i'm not spuing oil any where, if that helps. i only burn oil from the valve stem seals we changed... but did it wrong. haha.
Old Oct 31, 2011 | 11:12 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
May need a baffled pan.
Old Nov 1, 2011 | 02:22 PM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
I would hook up an analog oil pressure gauge to verify what your actual oil pressure reading is. Oil pressure isn't something you want to really just "hope everything is ok" with. If the oil pressure on the analog gauge is good, then it's either a problem with your sender or the electronic connection to the gauge in the dash itself. If oil pressure really is going low, then you may have to drop the pan and see what's going on down there.
Old Nov 2, 2011 | 12:09 PM
alexquade's Avatar
Car: 1992 RS
Okay, i checked my oil and it turns out i was 3 quarts low. Topped it off, and problems gone. Now its time to start saving major money to over haul this thing. Now that i kno its burning a lot of oil. Thank you all for your responses!!! Appreciate it!!!
Old Nov 2, 2011 | 12:54 PM
torque_is_good's Avatar
not picking on you but just out of curiosity;
how could you drive a vehicle that you know consumes oil and allow it to go 3 quarts low?
You should have a couple quarts of Wal Mart oil in the trunk at all times along with a rag and funnel.
Old Nov 2, 2011 | 01:30 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Originally Posted by torque_is_good
You should have a couple quarts ... oil in the trunk
A couple? I had a '71 Cutlass that used a quart every 60 miles. I kept a case of oil in the back! A quart to and a quart from work. But I only paid $300 for it.
Old Nov 2, 2011 | 01:45 PM
alexquade's Avatar
Car: 1992 RS
I have oil in the trunk. I was prepared. BUT! It has NEVER burned this much oil. Like itll be a quart to a quart and a half low at oil change. I guess its time to over haul it...
Also. I changed my valve stem seals. And since then its been burning worse. But. The o-ring, i think i put it on wrong. I cldnt put it on after the spring, so it went on befre. And as ive read, itll make a car burn oil bad doing that.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
