Engine/ Cam Break In?
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So I am completly rebuilding a L98. Intake mods and a crane cam 2032. What break in should I do? Any special fluids I should use?
Thanks in advance
Thanks in advance
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Engine/ Cam Break In?
ins't that a roller cam, no need to break it in !!
Engine: 5.7 L98
it is, but i mean the engine as a whole? changed all the rings ect... had to stripped down to the bare block andthing that has the ability to naturally wear and tear has been replaced. i mean i cant just drop the engine in and drive it down to the track right?
Engine: Lb9
Transmission: M20
I allway use gm eos on a new rebuild or a high zinc. and use a oil primer, Im cheap and just ground off the teeth off a old distributor.
Engine: 5.7 L98
that just gets added into the oil? will i have to do an oil change sooner then 3000? Going to use synthetic...
Engine: Lb9
Transmission: M20
yes add it to the oil!, I ussually change the oil after a couple warm up cycles and timing adjustment, change the oil and run synthetic maybe around the 3k mark.
