timing issue
Old Nov 2, 2011 | 02:38 PM
Gecz28's Avatar
Car: 88 iroc vert
timing issue
i have a new gm 1piece rms shortblock and i bought a new balancer from summit. i went to break in the engine and time it. the timing marks on the balancer are around 10 oclock but the pointer is at about 2 oclock???? the engine does run fine, just needs tweaked. im almost positive the dots on the cam are lined up with the crank. if it was that far out, i dont think the engine would even start??
i noticed it was leaking oil around the pan gasket so i pulled the engine, drained the oil, and dropped the pan, and what did i find...a head of the first main cap bolt busted off.
now, could that bolt have been over torqued from the factory or could it have something to do with the balancer, being the front main cap bolt???
heres the balancer i got
http://www.summitracing.com/parts/RNB-594-012/
Old Nov 2, 2011 | 03:33 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You would have felt some pretty serious vibration for the damper to have cause the bolt to fail. More likely is it wasn't properly torqued (too loose will break it as well as too tight).
Where is the timing mark on the damper ring relative to the keyway in the hub? They should be pretty close together.
Did you have the woodruff key in the crank before you installed the damper?
Old Nov 2, 2011 | 03:50 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: timing issue
to the best of my knowledge small blocks came with 2 different timing locations. there is the 12 oclock & the 2oclock. just use the correct pointer.
Old Nov 2, 2011 | 04:12 PM
Gecz28's Avatar
Car: 88 iroc vert
Re: timing issue
i will have to check where the key way and the timing mark are.
can i just put a new bolt in and torque it down and good to go?
Old Nov 2, 2011 | 04:23 PM
five7kid's Avatar
I would pull the cap and check it and the bearing and crank. Then reinstall with two new bolts. Wouldn't hurt to loosen and retorque all of the others while you're at it.
five7kid's Avatar
There is no 10 o'clock pointer.
Old Nov 2, 2011 | 04:48 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: timing issue
yea, hes probably got a 12 oclock balancer using the 2 oclock pointer. yup, no such thing as 10 oclock on a small chevy.
Old Nov 2, 2011 | 05:28 PM
Gecz28's Avatar
Car: 88 iroc vert
Re: timing issue
yea the marks are very close, almost lined up.
is that a correct balancer for my application? engine has 330 hp at best? and why would the marks be off?
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
