Sensor Pass Side Below Headers
Old Nov 16, 2011 | 06:33 AM
305eatsRice's Avatar
Car: 1987 Camaro
Can anyone inform me what the sensor is below the headers towards the firewall and right above the starter is? 87 camaro 305 ccc automatic. Its in a tight spot in the block. it broke of and i only noticed it while changing the starter.
Old Nov 16, 2011 | 06:50 AM
Re: Sensor Pass Side Below Headers
Sounds like the knock sensor, if you're talking about being screwed into the coolant drain hole on that side, exactly halfway down the side of the block and about 1" above the oil pan rail.
Old Nov 16, 2011 | 07:10 AM
Car: 1987 Camaro
I dont remember if it is right above the oil pan rail or not. I'll have to take a look later if it ever stops raining.
Old Nov 16, 2011 | 03:39 PM
torque_is_good's Avatar
there are 2 items on the right side of the block
I'm not sure with the 87's but on the 89
one is the fan switch
the other is the knock sensor
Old Nov 16, 2011 | 03:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The fan switch and knock sensor are both on the right side of the engine, but the fan switch is in the head.
Old Nov 16, 2011 | 04:28 PM
Twin_Turbo's Avatar
It's the knock sensor, it's right above the pan rail:
Old Nov 16, 2011 | 05:11 PM
Car: 1987 Camaro
Thanks for all the reply's. I havent had a chance to get it out yet, or even look at it again due to the rain. Tomorrow i think might be clear enough to try.
Old Nov 16, 2011 | 05:15 PM
Twin_Turbo's Avatar
That thing screws in the coolant drain. With a bit of luck there's enough deposits in the block to plug it. If not, it will leak out all coolant if you take it out. If it doesn't leak, don't poke in the hole with a screwdriver, then it will leak guaranteed.
Old Nov 17, 2011 | 12:48 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
"above starter"
"towards firewall"
"tight spot in block"
To me that describes the fan switch more than the knock sensor, but neither are in a "tight spot" on my motor, but if it's below headers and "in" the block, then it's definitely the knock sensor.
Let us know which one it is.
Old Nov 17, 2011 | 06:38 AM
Twin_Turbo's Avatar
The knock sensor is in a tight spot with the engine in the frame, hard to reach with the crossmember obstructing it.
Old Nov 17, 2011 | 08:46 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
That's what confuses me because the cross member would be away from the firewall.
I would describe it's location by, " in front of starter over cross member."
Old Nov 17, 2011 | 06:23 PM
Car: 1987 Camaro
Sorry I have not had a chance to get under the car due to the rain/ and working my tail off.
Old Nov 19, 2011 | 10:49 PM
Car: 1987 Camaro
It was the Fan switch sensor that was broken. I did not get a chance to get pics.
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Aug 5, 2015 11:57 PM
