Engine mystery - im stumped!
Old Nov 23, 2011 | 06:17 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Engine: some sort of small block
Hey guys,
just bought my 1987 camaro a couple months ago and its been running good, only thing is the guy i got it from knew nothing about it! Id LOVE to know what engine i have.
the vin numbers on the windshield and center console dont match, the one on the windshield says its a 350, the other says its a 305.
it has a 5 spd manual and tpi setup, but its been messed with a lot. someone put in a push start drag strip ignition, new gauge cluster, and electric cutouts.
i pulled a valve cover and got this number: 14014416. i searched everywhere on the block for a casting number and found a "207" over where the starter is, and "201" on both sides of the block. as far as i know theres no other numbers readable with the motor still in the car. the engine block is also painted orange, and i dont think they came painted factory? but hey im still fairly new to these cars does anyone know what this engine could be?
Old Nov 23, 2011 | 06:35 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
Re: Engine mystery - im stumped!
ok also just checked numbers online, the heads are out of an 80-86 car, so that proves the heads cant be stock, the whole motor is perhaps older? and if 201 or 207 refers the the last 3 digits of block casting number, it still doesnt help because one is 305 (201) and the other is 350.
"201" appears on both sides of the block sort of in the middle, and 207 is right above the starter on the block, passenger side. one over-ride the other? any help appreciated
Old Nov 23, 2011 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
What # is here
Old Nov 23, 2011 | 06:49 PM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
[quote=vetteoz;5102547]What # is here
it should say right there what it is my 87 said 5.7 on it and both my 91s say 5.0 they were all tbi maybe tpi is different about it
Old Nov 23, 2011 | 06:53 PM
lolvtec's Avatar
Axle/Gears: 2:73...
theres the 87 350
Old Nov 23, 2011 | 06:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
id be more concerned about this than worried about what motor it has.....
id check to make sure the vin number on the dash matches at least 1 other vin number on the car.
Old Nov 23, 2011 | 07:05 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by lolvtec
theres the 87 350
Late model engines stamped 5.0 or 5.7 have the engine # cast on the opposite side at rear
Old Nov 23, 2011 | 07:12 PM
lolvtec's Avatar
Axle/Gears: 2:73...
well the 87 he has should have it on there i think i know its hard to look at with the motor in there
Old Nov 23, 2011 | 07:15 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
yeah i cant see that number at all right now, been trying for a couple hours to see it from above and under the car, no luck
i did find another "207" in raised print above the oil fiter on the drivers side. these are the only numbers i can see with the engine in the car, plus the number on the heads. any significance to these numbers?
Old Nov 23, 2011 | 07:20 PM
lolvtec's Avatar
Axle/Gears: 2:73...
try a small auto tech mirror if you have the money to spend advanced auto has thing that flexes and has a camera on the end
Old Nov 23, 2011 | 07:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Originally Posted by vetteoz
What # is here
And just what are you doing with a factory sealed crate vette TPI motor??
Old Nov 23, 2011 | 07:32 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
good idea, that could work. might have to try that because im dying to figure out what this motor could be!
Old Nov 23, 2011 | 07:52 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
ill definitely check this out tomorrow too
Old Nov 23, 2011 | 08:16 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
There should be a partial engine vin number on the front passenger side of the engine. Look behind the AC pump. There is a flat spot between the front end of the head and the ac pump or alternator (forget which one is on that side) Use some WD40 to clean up so you can read it. It should read something like v0216awk. For example Awk is the suffix code for an 89 camaro/firebird 350 TPI engine
2nd post has a pic
https://www.thirdgen.org/forums/engi...-question.html
Old Nov 23, 2011 | 08:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Also look for the stamped numbers on the pad in front of the passenger side head. If the block has been decked, then those numbers will be gone.
If the VIN on the cowl says the car originally had a 350 then it didn't originally have a T5. GM never put the T5 behind a 350. Only the 305 V8.
The casting number on the engine bellhousing can only confirm if it's a 350 or a 305 bore block and roughly what year range it's from. It won't tell you want it came from.
Ignore the info in the center console. That could easily be swapped from another car. The cowl tag is usually the most accurate but should be confirmed with other VIN numbers on the car. There are VIN stickers throughout the car if you know where to look for them. Look in the spare tire compartment to see if there's a sticker attached to the outer skin. Most of the other stickers require removing interior paneling to see them.
Old Nov 23, 2011 | 08:34 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah hopefully it isnt one of those VIN swapped cars... that'd be bad...
84chvyz28's Avatar
Car: 1987 IROC-Z28
2nd post has a pic
thanks! ill have to check this out, the picture is really helpful i wasnt sure what i was looking for, especially because everythings covered in orange paint!
Old Nov 23, 2011 | 08:36 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
thats another thing im afraid of
Old Nov 24, 2011 | 08:23 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
ok so i got the number off the pad, v1012CDJ. there was a smaller one under it, but its impossible to read :/ now i looked into it and
CDJ can be off of a 305 (1985 car LG4), 267 (some 70's car), and 350 (72 vette). the heads are the "416" heads, which from what ive gathered are off an 80-85 car. so am i right in putting 2 and 2 together and assuming i have a 305?
Is there any glimmer of hope that it could be a 1972 350?
Old Nov 24, 2011 | 08:42 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
CDJ can be off of a 305 (1985 car LG4),.......
Looks that way but only the block casting # at rear will confirm
Old Nov 24, 2011 | 09:07 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
ok, i also posted some pics of what it looks like on my profile. guess ill have to wait to know 100% until then ill assume its the 305, makes more sense at this point haha
Old Nov 24, 2011 | 10:21 PM
AlkyIROC's Avatar
Car: 87 IROC L98
My listing for CDJ
CDJ 1982 267 2 Roch E2ME carb.
CDJ 1985 305 150 4 Roch E4ME carb.
CDJ 1972 350 200 - base, tur 400, NB2
What side of the engine is the dipstick on?
Passenger side, it's probably a 305 but may also be a 267. Driver's side, it's probably the older 350.
Old Nov 25, 2011 | 05:29 PM
84chvyz28's Avatar
Car: 1987 IROC-Z28
the dipsick is passengers side, so i guess that pretty much rules out the older 350 block
what is a 267 exactly? is there any way of telling that apart from a 305? i had no idea this was even an engine gm really used at all
Old Nov 25, 2011 | 06:04 PM
travis401's Avatar
Car: 91 Camaro RS
its a 3.5" bore 3.48 stroke. wasnt widely used, and tossed out the window in the 80s. chances of you having a 267 are slim to nil.
Old Nov 25, 2011 | 07:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
The odds appear that you most likely have a 305 that was originally a carb engine that someone put a TPI system into.
Based on your original post, you have an original 350 car from the cowl tag. Powertrain and interior were swapped from a 305 car from the console decal.
Hard to say what someone was trying to do but no matter how you look at it, you have a 305 that was probably pawned off as being a 350.
Old Nov 25, 2011 | 09:48 PM
travis401's Avatar
Car: 91 Camaro RS
its most likely either a 350 car that had the 350 replaced with a 305 and the tpi thrown on, or its a 305 car that a tpi was thrown on with a swapped vin plate.
BRoss99
Aug 10, 2025 05:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
cstrobel65
Aug 15, 2015 10:19 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Elliswon
Aug 10, 2015 12:33 PM
