oil leak
Old Dec 19, 2011 | 01:13 AM
jmr450's Avatar
oil leak
I just bought an 89 firebird with the 2.8 v6. when i start the motor it pours oil from around the oil filter housing. but doesnt leak when not running. what could this be?
Old Dec 19, 2011 | 01:25 AM
NathanLewis's Avatar
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Re: oil leak
sounds like the seal that goes around the oil filter when it screws in.
Old Dec 19, 2011 | 06:12 AM
ex-x-fire's Avatar
Re: oil leak
Theres a gasket that goes between the filter housing & the block, its a common gasket. It might look like this one.
Old Dec 19, 2011 | 06:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: oil leak
Verify that you're using the correct filter--don't ask me why I'm suggesting that .
JamesC
Old Dec 19, 2011 | 07:00 AM
grumpyvette's Avatar
Re: oil leak
JamesC
that cracks me up and brings back memories of a neighbor who used a spare oil filter from his previous car on his new truck, who had a similar rather messy smokey problem when the wrong filter failed to seal correctly
Old Dec 19, 2011 | 12:54 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: oil leak
ive missed the oil filter seal before, it was a mess.
Old Dec 20, 2011 | 10:38 AM
jmr450's Avatar
Re: oil leak
how do i remove the filter housing?
Old Dec 20, 2011 | 12:20 PM
ex-x-fire's Avatar
Re: oil leak
You have to remove the large center bolt.
I haven't been under one those v6 cars in awhile, you might have to remove the engine mount.
Can you take a picture?
Old Dec 21, 2011 | 11:24 PM
jmr450's Avatar
Re: oil leak
i got it fixed. the gasket was not even there. thanks for the help
Old Jan 7, 2012 | 11:09 PM
camarobear's Avatar
Re: oil leak
Hi, i have the same problem with a 86 camaro 2.8 v6. I have no idea on how to remove the oil filter housing. Do i remove the bolt that the filter goes on? Or is it on the outside by the sensors ?
Old Jan 8, 2012 | 08:48 AM
ex-x-fire's Avatar
Re: oil leak
Here's a picture to show you, it the large bolt that goes through the housing. You might have to loosen the engine mount bracket.
Old Jan 9, 2012 | 10:16 PM
camarobear's Avatar
Re: oil leak
Thank you so much! That helps a buch One more thing if you don't mind. Would you happen to know if there is any specific torque specs for when i'm putting the bolt back on?
Old Jan 9, 2012 | 11:13 PM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
Re: oil leak
same problem, for me its the oil sending unit(adapter that goes to the filter), my mechanic wants to charge me $80 to replace it.
Old Jan 9, 2012 | 11:37 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: oil leak
That's a easy fix on the 2.8, really shocked he would charge you that much.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
