Fuel Pump Pressure
Old Jan 10, 2012 | 09:41 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Fuel Pump Pressure
I was looking at the difference between the o.e fuel ppump and the new bosch one i bought. it says the old one pushed maximum flow of about 90 psi and the one i have now is only 12psi. is this bad? its installed already.
Old Jan 10, 2012 | 12:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Fuel Pump Pressure
Not knowing which Bosch pump you installed I can't comment directly on it.
However, your MPFI engine isn't going to run with 12 psi of fuel pressure. That sounds like a carburetor FP.
Service spec for fuel pressure is 43 - 47 psi (or there-abouts). Nominal of 43.5 psi.
RBob.
Old Jan 10, 2012 | 01:00 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
dangit. i might have to redrop the tank then.. ill show you witch one. let me uplaod
Old Jan 10, 2012 | 01:02 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
this is the fuel pump set i bought.
Old Jan 10, 2012 | 04:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
This doesn't tell me a lot. Have a link or part # for the set up?
The other thing to do is to put a fuel pressure gauge on it. There is a pressure port at the rear of the fuel rail. Can get to it from between the rear of the plenum and the distributor. As above, the fuel pressure should be between 43 & 47 PSI.
There is a red pigtail near the brake booster. Run that to battery + (with ignition off). That will power up the fuel pump.
RBob.
Old Jan 10, 2012 | 05:00 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
The part number is : 69222
Bosche.
ok so i am going to borrow a FP Tester, do i have to have to connect the red pigtail to the battery or is it ok if i just connect the batery to power it,??
Old Jan 11, 2012 | 08:59 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
bump
Old Jan 11, 2012 | 09:19 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
That would be the correct pump. Specs say it pushes a max of 60 psi unregulated. I am not sure where you found that it only pushes 12 psi? Did you use a gauge on in to verify?
Old Jan 11, 2012 | 09:21 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
im not sure if its the right one. yesterday i looked it up and i think the one its supposed to be isnt it. let me check..
Old Jan 11, 2012 | 11:00 AM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
this is the one i bought http://www.oreillyauto.com/site/c/de...0401&ppt=C0025
Old Jan 11, 2012 | 01:06 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Looking at your link I can't see why the one you have is not the correct one. All the specs and applications seems to fit your car. I recently replaced the fuel pump on my carb'ed ZZ3 and when I went to my local Chevy dealership, the parts guy said there are basically two types of fuel pumps, carb and fuel injection. All I told him was I have a carb'ed engine and he knew what one I needed. Carb'ed fuel pumps are in the 14 psi range and FI fuel pumps are in the 45 - 60 psi range. Either it works or it won't! And FYI to any carb'ed people reading this thread, fuel pressure at the carb --a Rochester q-jet for example-- is no more than 5.5 psi. A $20.00 Holley fuel regulator with a pressure gauge works fine.
Old Jan 11, 2012 | 01:56 PM
dellman83Z's Avatar
As far a pressure, it should work, but there are two different part numbers between a v6 and a v8. Bosch 69222 is for the v6 and the one you bought is for a v8. I really am not sure what the difference is though.
Old Jan 11, 2012 | 04:53 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Yes but the problem is that my engine is MPFI
Old Jan 12, 2012 | 09:07 AM
dellman83Z's Avatar
Both of those are for mpfi
92camaroJoe
Jul 29, 2023 07:57 PM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
