Sensor Replacement
Old Jan 19, 2012 | 09:15 AM
mgilorma's Avatar
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
Sensor Replacement
Hey guys,
I have a $50 coupon at advance auto and want to spend it on replacing some sensors which I am pretty sure have never been replaced. So far I'm getting:
o2 sensor
knock sensor
air charge temp sensor
air cleaner temp sensor
MAP sensor
coolant temp sensor
should I get a new throttle position sensor? Anything else I should pick up?
Old Jan 19, 2012 | 09:20 AM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
Re: Sensor Replacement
if you want you could get me some injector o-rings lol, jp.
nice though.
Old Jan 19, 2012 | 09:47 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Do you have any codes telling you something is bad? Do you have bad gas mileage? Do you have poor throttle response? do you have overheating issues? Don't spend $ "just to spend $. If it ain't broke, don't fix it.
Old Jan 19, 2012 | 11:31 AM
mgilorma's Avatar
Car: 90 RS
I tore down the engine two years ago, replaced all gaskets, put new springs and seals in the heads and swapped in a LT1 cam. Before that I was having all kinds of problems. After putting the car back together and doing a little prom tuning it runs pretty well when it gets up to normal operating temp. Now that I have a little tuning experience I realize that some of the parts I re-used I should probably replaced since they are all 20+ years old. I'm trying to insure the readings that the PCM is making decisions based off of are as accurate as possible.
Old Jan 20, 2012 | 06:25 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
just because are old doesnt mean need replaced i would really leave alone unless there really is an issue with any of them
really.
aftermarket new sensors arent gonna be any better quality than the original delco ones
really.
o2 sensor woul dbe good idea to replace sure
but the rest not unless they are faulty
imho theres better things to spend the money on
really
like nicer secondary wires and better stronger coolant/fuel hoses and better ign coil and better ign module, better oil, and such
have fun!!
Old Jan 20, 2012 | 07:17 AM
mgilorma's Avatar
Car: 90 RS
I understand the idea of "if it ain't broke don't fix it"
However, its not like my car is operating at peak performance. Ideally I would like to electrically test everything that I am replacing to see if they are operating within spec. I will do some searching around to find out how to do this, if anybody knows of some good links please let me know.
Old Jan 20, 2012 | 11:10 AM
Car: GTA
Originally Posted by Randy82WS7
.....aftermarket new sensors arent gonna be any better quality than the original delco ones.....
I want to object to that 1 portion of your statement.
I had to replace my MAF earlier this year & the aftermarket one I got from Autozone is newer technology & I believe can flow more CFM, due to (what appears to me) the sensor's less cross-sectional area in the air stream. Besides that.....It is hard to believe that in 20 yrs, the technology to measure the airflow would not have gotten better at more accurate readings.
Old Jan 20, 2012 | 12:04 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
he doesnt have a maf sensor, I say if it ain't broke,dont fix it,but if anything it prob woulndt hurt to get a new o2 sensor.
Old Jan 20, 2012 | 12:05 PM
ninetyone's Avatar
Axle/Gears: 3:42
I think i would do cap ,rotor,plugs if anything
Old Jan 20, 2012 | 12:50 PM
mgilorma's Avatar
Car: 90 RS
I replaced cap, rotor, wires and plugs when I rebuilt the engine. Less than a thousand miles since then. And again, I'm definitely not running at 100% so I'm trying to eliminate any weak links. I don't know how many of you guys have done any prom tuning, but if my MAP readings are off by 10% that can directly affect what the PCM is doing to compensate for what it believes are low or high numbers.
Old Jan 20, 2012 | 02:06 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
O2 sensor, probably not a bad idea to replace, but stay away from the Bosh O2 sensor replacements.
Don't expect to gain any performance with new sensors.
bamaboy0323
Sep 3, 2015 06:07 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
mizz0313
Aug 12, 2015 06:45 AM
92purpz28
Aug 11, 2015 02:30 PM
