87 camaro help pls
Old Jan 23, 2012 | 08:11 PM
87iroczcamaro's Avatar
Car: 87 irocz
Engine: Carb 350
Transmission: Built Turbo 350
87 camaro help pls
I have an 87 iroc camaro and was driving it for the first time since I got it I Whent to dothe 0-60 test it got there in 15sec it has the fallowing mods Holley carb, Holley intake, Holley fuel pump, Holley regulator, hedman headers, flow master muffler, b&m mega shifter, comp cams bord 60 over fully built Turbo 350 the time I got seems very slow for Whut it has its slower than then the stock 350 summthing is not right eney help is appreciated it has the 350 I bought it off a guy who did all this Idk about whuts inside the engine is true without taking it apart but everything else checks out it a pre 71 block
Old Jan 23, 2012 | 08:20 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: 87 camaro help pls
You'll have to tell us what it is doing exactly, not just that it's slow.
When you did the test was the engine warmed up and were your carb secondaries opening as they should?
Assuming this is a conversion to carburetor, it is very important to tell us exactly what type of distributor you are running (don't just say HEI) and how it is set up.
Some people leave the computer in the car to control certain things like the old computer controlled distributor. I doubt this is the case here, but it is a situation that can explain very poor performance.
Are you getting any misfires? Is the engine revving up smoothly?
Old Jan 23, 2012 | 08:30 PM
Car: 87 irocz
Engine: Carb 350
My Disturbitor is a bit worn so I got an accel to replace it just put new plugs in wating on the wires from msd the temp was about 180 and have not checked the Carb yet I was going to do that next
Old Jan 23, 2012 | 09:30 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Is your performance the same as before the distributor swap?
What model Accel distributor did you get?
Have you went through the process of setting up the timing curve yet?
there is info in the links of my signature for setting up distributors.
Old Jan 23, 2012 | 10:07 PM
Car: 87 irocz
Engine: Carb 350
I have not replaced the distributor yet the stock one is in there now but a distributor should not5 make that big of a difference Idk about the timing curve as I did not build the car but ill check it and do another run in the morning
Old Jan 23, 2012 | 10:45 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I don't really consider that an answer because I don't know for sure which distributor came stock on your particular car. Was it originally a TPI car and converted to carburetor?
You said your distributor was worn so you got a new distributor to replace it, so it sounded like you had replaced it.
When you say worn, what exactly do you mean there?
Old Jan 23, 2012 | 11:22 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
if the ignition timing isn't right, it will make a huge difference.
a computer control distributor will have very little advance. i may very well be wrong, (which i am wrong too often) but IIRC, the ignition module can add about 8 degrees without the ECM. 8+ base timing of 12 tops is 20 degrees of total advance.
20 degrees on a motor that needs ~34 at WOT will be terribly slow, not to mention very bad fuel mileage.
if i am wrong and the ignition module does not add any timing, and if you do have a computer control distributor, im surprised you even got it to 60 MPH.
Old Jan 24, 2012 | 08:14 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
You're being very elusive about giving information concerning your distributor.
If you just post a good picture of it, to include the wire connections (not the plug wires), then we can give you your answer quickly.
An yes, a distributor problem can absolutely cause extremely poor performance.
Old Jan 24, 2012 | 09:13 AM
Car: 87 irocz
Engine: Carb 350
I went out to start it ran like crap it sounds like it was missing bad checked my distributor and wires thay where trashed witch probably is the problem thay where not able to Handel the high load required by my enginein so it looks like thay gave out I don't know why the guy put thim on in the first place
Old Jan 24, 2012 | 11:13 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
It sounds like this is the first time for you driving or even looking at this car ??
It also sounds like when you use the word "distributor" you really mean to say "distributor cap".
If you are that lost, then why not do what is asked and post a good picture of what you're dealing with so you can get some good advice?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
BADNBLK
Nov 16, 2016 09:12 AM
porkenstein
Convertibles
Aug 31, 2015 12:54 PM
