86 Iroc 305 TPI Over Heating HELP!!!
Old Feb 4, 2012 | 04:58 PM
ChevyManDanJR's Avatar
Car: 1986 Camaro Iroc Z
Transmission: 700R OD
Hey guys, need some serious help. Besides my ticky lifter, my car has started to run dangerously hot after driving for about 15-20 minutes. I've been having to turn the air on in the car to expel hot air from the car in order for the temp to come down. Sometimes, even pull over to let it cool. All fluids are topped off, no leaks that i can find and the car doesn't use no coolant. Sooo now I'm stumped as to why she'd be running so hot. It's to the point where I don't want to take her out anymore out of this fear. I checked and the fan does come on too, so at this point I'm lost. Anybody have similar issues or any knowledge of the problem? As far as I can see everything in the car is original, 305 stock tpi engine, no mods. Could it be time for a brand new engine altogether??
Old Feb 4, 2012 | 05:03 PM
ex-x-fire's Avatar
Re: 86 Iroc 305 TPI Over Heating HELP!!!
Might have a t stat thats not opening.
Old Feb 4, 2012 | 05:18 PM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
Did you check the oil pressure?
Old Feb 4, 2012 | 05:30 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Old Feb 4, 2012 | 06:04 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
Make sure besides the t stat that the air dam at the bottom of the car is still there if its missing it might over heat
Old Feb 5, 2012 | 09:23 PM
Cosmik Debris's Avatar
Do the fans come on?
Old Feb 16, 2012 | 08:07 PM
Fan definitely comes on. I actually just learned that the thermostat was taken out of the car cuz it robbed power.
Old Feb 16, 2012 | 08:09 PM
just found out there's no thermostat at all. was taken out by the po
Old Feb 16, 2012 | 09:38 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Thermostats do not rob power, put the correct thermostat back in the car and go from there. Chance your coolant while you are at it.
Old Feb 16, 2012 | 09:42 PM
89RsPower!'s Avatar
However a lack of a t-stat almost always results in a car running cold and never reaching operating temperature, so step one, install proper t-stat and replace coolant with a 50/50 mix. See what happens after that and post your results, chances are there is some reason this engine is running so hot, and the stat was removed in an effort to hide the real issue... I'd recommend pressure testing you cooling system, if it holds pressure replace your rad cap and go from there. If this is a bone stock engine with stock everything working properly it should never over heat.
Old Jun 18, 2012 | 09:50 AM
Hey guys after some garage time and debate, I've decided to replace the entire radiator cuz it looks original and the waterpump which seems questionable. Did notice that when the car was last started that the fluid in the radiator was NOT moving. I figure might as well go ahead and get some new money in there anyways, can't hurt. Planning on putting it all together next weekend and going from there. Will update the details after the installation. Thanks everyone!
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
